Tdr Cable Test
prince.p
Level 3
Level 3
Hi freiend,
i need to test the cable status from cisco 2960 switch to connected device,in the pair c and d it shows shot. i need your suggestion weather i need to change the cable are not . below i attached the report
tri-SW2#show cable-diagnostics tdr i
tri-SW2#show cable-diagnostics tdr interface gi0/13
TDR test last run on: May 20 22:40:02
Interface Speed Local pair Pair length Remote pair Pair st
Gi0/13 100M Pair A 17 +/- 0 meters N/A Normal
Pair B 17 +/- 0 meters N/A Normal
Pair C 18 +/- 1 meters N/A Short
Pair D 17 +/- 1 meters N/A Short
Leo Laohoo
Depends on the downstream device. The results from the TDR tells me, possibly, the remote end device is only a 10/100 BaseTx and doesn't require PoE.
If this is the case, then there is no need to do any replacement.
6 Replies 6
Mark Malone
thanks for your post.
what cable i want to change.whether the remote end cable ie IO box to
device or Cable from patch panel to switch or the horizontal cable ie from
Patch panel to IO box
start by changing the one you just tested g0/13 and then rests see if you still have an issue with it
Leo Laohoo
thank all lot. my doubt is cleared.
