Technical clarification ISR 891
Guys
Can you please let me know what’s the maximum bandwidth (ADSL/internet) supported by ISR 800 series routers … particularly 891 security model.
Appreciate your assistance in this regards
Srikanth
23 Replies 23
Leo Laohoo
With CEF enabled, the 890 can push up to 51.20 Mbps.  The value is express in HALF duplex and no encryption applied.
If you want the value expressed in full duplex or with encryption you just halve the value.
If you want want full duplex and with encryption you factor the value 51.20 to 4.
Please don't forget to rate useful posts.  Thanks.
Thanks you so much for the reply Leo
I have to terminate 32MB link and with DMVPN solution (ipsec over gre + NHRP)
Could you please advise me the cost effective product in ISR please
Thanks in advace
Srikanth
Hmmmm ... 32 Mbps, Full duplex and encryption.  32 x 4 = 128 Mbps.
If you do not intend to "grow" this WAN link then your best candidate is the 1941.
Attached is a Cisco document, router perforrmance, that will give you the maximum bandwidth supported by each router models based on half duplex and no encryption.
Take note that the business unit that routinely updates this particular document has been disbanded and this is the last copy of it's kind.  It does not include the 3925E and 3945E and other ASR stuff.
Vishnu Asok
Hi Srikant
If you expecting a throughput of more than 25 Mbps on your Cisco 891 router with NHRP configuration, you should rather be cautious as there will be frequent occurences oh HIGH CPU which would impact your performance!!.
As you add ACL's, encryption, compression, etc - performance will decline significantly from the given numbers, unless it is a hardware-assisted platform
Please go through below link which shows the performance data sheet of most of the Cisco routers
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
Cheers
Thanks so much Leo and Vishnu. Your inputs really helped me to finalize the product..
Bandwidth   Required in MBProposed model
30CISCO1941-SEC/K9
48CISCO2921-SEC/K9
32CISCO1941-SEC/K9
42CISCO2921-SEC/K9
36CISCO1941-SEC/K9
188ASR1002-5G-SEC/K9
I was looking for cost effective solution, so went for ASR1002-5G-SEC/K9 as DMVPN hub. Please do correct me If am wrong.
Thanks again
How big is your bandwidth?
Hi Leo
Here is my bw table against each branch ...
Sr.NoBranchNo of Camera'sBandwidth   Required in MBProposed model
1Branch 11530CISCO1941-SEC/K9
2Branch 22448CISCO2921-SEC/K9
3Branch 31632CISCO1941-SEC/K9
4Branch 42142CISCO2921-SEC/K9
5Branch 512CISCO891-K9
6Branch 612CISCO891-K9
7Branch 712CISCO891-K9
8Branhc 812CISCO891-K9
9Branch 912CISCO891-K9
10Branch 1012CISCO891-K9
11Branch 1112CISCO891-K9
12Branch 1212CISCO891-K9
13Branch 1312CISCO891-K9
14Primary   Hub00ASR1002-5G-SEC/K9
15Secondary   Hub00ASR1002-5G-SEC/K9
Every branch has ACLs/Encryption/full deplex ...video traffic
Hi Srikanth
Your choice of Models looks good. ASR series are very powerful routers and it makes sense to deploy them at the HUB sites considering future expansions.. But just wondering if you made a comparison between 7206 VXR NPE-G2 and ASR  performance before finalising? I am only giving you some ponters to think about  :-)
Yes yes, I did, thanks for heads-up Vishnu
Looks like you did your homework.  ASR 1K for a hub is a "no brainer".
If you've got funds, I'd be looking at ASR 1004 with ESP10 minimum.
Points to consider:
1.  Flash/CF are cheap nowadays, consider getting the MAXIMUM amount of DRAM; and
2.  Don't forget to upgrade the bootstrap of the routers you are getting.
Just in case you are looking at a router that only has mobile wireless as a WAN link, you can consider the 819 (released 2011).
I'm just reviewing your table of branches against the number of IP cameras per site.  How much bandwidth does each camera pushes?
Thanks for the inputs Leo. Each camera support 2mega pixels and pushes 2MB with no video encryption. We are not allowed to go for WAAS/any WAN optimizers to encryp the video as per the client compiance statement
So going with ASR1002-5G-SEC/K9 as Hub is not a right choice ? I need atleast 200MB at hub to support all IP cams at various branches in Middle East (Same country)
I had pulled the mini bom for ASR 1004 with ESP10, assuming the last mail is on Ethernet/GE. Please kindly advise if i missed any ...
ASR1004-10G-SEC/K9ASR1004 VPN+FW Bundle w/   ESP-10G,RP1,SIP10,AESK9,License1
ASR1000-RP1-BUNCisco ASR1000 Route Processor 1, 4GB DRAM,Bundle Component1
ASR1000-SIP10-BUNCisco ASR1000 SPA Interface Processor 10, Bundle Component1
ASR1000-SIP10Cisco ASR1000 SPA Interface Processor 101
SPA-2X1GE-V2Cisco 2-Port Gigabit Ethernet Shared Port Adapter1
ASR1004-PWR-ACCisco ASR1004 AC Power Supply2
CAB-ACU-RAPower Cord UK, Right Angle2
MEMUSB-1024FT1GB USB Flash Token1
M-ASR1K-RP1-4GBCisco ASR1000 RP1 4GB DRAM1
M-ASR1K-HDD-40GBCisco ASR1000 RP1 40GB HDD1
ASR1000-SPASPA for ASR1000; No Physical Part; For Tracking Only1
ASR1000-ESP10Cisco ASR1000 Embedded Services Processor, 10G1
FLASR1-FW-RTUFirewall Right-To-Use Feature Lic for ASR1000 Series1
FLASR1-IPSEC-RTUEncryption Right-To-Use Feature Lic for ASR1000 Series1
SASR1R1-AESK9-34SCisco ASR 1000 Series RP1 ADVANCED ENTERPRISE SERVICES1
ESP5 is a good choice.  But if I'm allowed to play a "devil's advocate" what happens if you or the organization wants to bump up the bandwidth.  I mean each camera pushes 2mb of data, fine by that, but what about the users?  Is this network you are building for IP Cameras only?  What about user data?  VoIP?
Another thing, I have never deployed IP Camera before so that was me, I'd set up one or two sites first and test the performance of everything before purchasing the rest of the kit.
Hold on ... Something's not right here.
You're in the Middle East so I would not have any idea what kind of power outlet standard you are using but you have "Power Cord UK, Right Angle".  Is this correct?
Another thing is "1GB USB Flash Token".  Really?  I wouldn't purchase this.
