Showing results forĀ
Search instead forĀ
Did you mean:Ā
Technical issues on NAT
Hi all,
I am kabeer,I have configured Cisco 1841 router PAT buts its not worked please find the below configuration details,
In LAN  interface
Interface gigabit Ethernet 0/0
no shutdown
Ip address 192.168.1.1 255.255.255.0
Ip nat inside
Exit
In wan interface
Interface gigabit Ethernet 0/1
No shutdown
Ip address 202.100.x.x 255.255.x.x
Ip nat outside
Exit
Access-list 1 permit 192.168.1.0 0.0.0.255
Ip nat inside source list 1 interface gigabit Ethernet 0/1 overload
Similarly I have configured static and dynamic nat but its not works in my customer place.
So kindly provide the solution for this issue.
Thanks and Regards,
Kabeer
18 Replies 18
cadet alain
NAT is done after routing so if routing is not working your NAT won't either.
can you post output of sh ip route | i 0.0.0.0
Alain
Hi cadet,
I have configured default-route to 202.100.x.x address.but its show the route but PAT not working.
So kindly provide the solution for this.
I am waiting for your reply.
kabeer
hi,
are you sure this is an 1841? usually they're FE ports.
also, are you able to ping the ISP or any public IP (8.8.8.8).
kindly post router config and hide sensitive info.
This is 1841 router,above mentioned configuration are configured manually,Its FE port because in client place only I am  configured PAT in 1841 router but Its not working,I am searching all forums and video tutorial the commands I have entered are correct but its not worked.I have connected isp cable directed to my laptop and Its working then I have connected to my 1841 router,I am able to ping public ip (8.8.8.8) through my router 1841  and through my laptop dirctly connected to 1841 FE0/0(LAN interface ) but its not working.I put extended ping command fron LAN interface to WAN but its not ping wan interface.please find the below configuration details of 1841 router.
Router#show running-config
Building configuration...
Current configuration : 726 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
spanning-tree mode pvst
interface FastEthernet0/0
description ####LAN####
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
description ####WAN####
ip address 202.100.x.x 255.255.x.x
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip nat inside source list 1 interface FastEthernet0/1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 202.100.x.x
access-list 1 permit 192.168.1.0 0.0.0.255
line con 0
line vty 0 4
login
end
So kindly provide solution for this issues.
regards
kabeer
hi,
you NAT config is ok and ISP connectivity looks fine.
try to update the IOS.
Hello
int vlan 1
No shut
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
hi,
pls find the below IOS details of 1841 router
Router#show version
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 15.0(1)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sun 18-Jul-10 01:16 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Router uptime is 19 minutes
System image file is "flash:c1841-ipbase-mz.150-1.M3.bin"
Last reload type: Normal Reload
Cisco 1841 (revision 7.0) with 235520K/26624K bytes of memory.
Processor board ID FHK144075RH
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1841             FHK144075RH
kabeer.
Hi all,
Kindly post a solution for my issues.I am waiting for anyone response.
kabeer
Asalaam Kabeer, did you manage to solve this one?
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
va alikum assalam bilal,
thanks for your response.
No bilal.I can,t able to find the exact solution for this issues.pls see above conversation for this issues.
Are you able to ping your default-gateway from the router to the 202.x.x.x address? Also, how are clients getting their addresses? If it is DHCP please make sure that the default-router address for DHCP is 192.168.1.1
Or try to plug in a laptop/PC with an IP of 192.168.1.2 mask of 255.255.255.0 and default gateway of 192.168.1.1 and then see if it works.
  1. First check if you can ping the LAN interface of the router
  2. Check if you can ping WAN interface of router
  3. Check if you can get past the WAN interface to the internet or something
You should be able to see NAT translations if this is working. 'show ip nat translation'
Hope this helps
Hi billal,
thanks for your response,
i have done everything.I just connect my laptop directly to that lan interface on router.From my pc i am able to ping lan interface and wan interface.but i can't able to ping gateway.i have configured one-to-one nat,dynamic nat and pat but configuration are done but nat translation is not working.Is there any bucks in ios?If i update ios which ios are preferrable for this router.
regards
kabeer
Kabeer, Can we try pinging the gateway from the router itself please?
Please provide the output of 'show ip route' and 'show run'
Thank you
Hi billal,
I can't able to ping the gateway from the router.I am dirctly connected ISP lease line to my laptop internet is working.
Router#show ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is 202.200.x.x to network 0.0.0.0
C    192.168.1.0/24 is directly connected, FastEthernet0/0
C    202.200.x.x/24 is directly connected, FastEthernet0/1
S*   0.0.0.0/0 [1/0] via 202.200.x.x
version 12.4
hostname Router
ip nat inside
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line vty 0 4
login
end
