telenetting
jonk34567
Level 6
Level 6
i am telnetting R2  from R1 router.if i need to login to the enable mode of R2 router via telnet , do i need to configure enable password on R2 router ?
 is there any way to do that without enable password ?
Mark Malone
Hi you could try set a username with secret on the router then under the vty set login local , see if that works
username test priv 15 secret cisco
line vty 0 4
login local
