Telnet CE500
microtel
Level 3
Level 3
Can u you help me how to telnet CE500 from the ip address of vlan management
Thank u
5 Replies 5
chris.baird
Level 2
Level 2
What is a CE500?
You can have only the VLAN 1 enabled so when you telnet anywhere it will be sourced from the interface address of VLAN 1.
Please rate if this helps.
Chris
rajinikanth
Level 6
Level 6
Create the interface vlan1
using the command
(config)#interface vlan1
then configure the ip address
(config-if)ip address x.x.x.x 255.x.x.x
Then try using this ip to telnet
Hope this helps you
RAJ
Hi RAJ,
For information, the console port is not available on CE500
Thanks for your help
sirisak.c
Level 2
Level 2
You should use CNA version 4.1
If you mean that this is a catalyst express 500.
according to the CE500 Q&A, neither Telnet nor CLI are available, and no future support is planned:
Q. Are there plans to add CLI or Telnet to Cisco Catalyst Express 500 Series Switches?
A. No, there are no plans to add CLI or Telnet to these switches.
Check this link to the FAQ:
Q&A
http://www.cisco.com/en/US/products/ps6545/products_qanda_item0900aecd80322b09.shtml
HTH,
GNT
