Telnet connection from home network
sany98
I'm trying to setup my first home lab but I'm having an issue with telnet from my home network. I have successful connected an router 2811, switch 3560v2 and an pc1. 2811 gets internet access form my home router (netgear) and switch and pc1 gets access through 2811. I can ping 2811 from pc1(192.168.2.2) and have access through telnet. When I try to telnet from pc2(192.168.1.2) to 2811 it doesn't work, however I can ping 2811 and I get answer but no telnet connection. Thank you in advance!
Here is config print:
R3#show running-config
Building configuration...
Current configuration : 1129 bytes
version 12.3
hostname R3
boot-start-marker
boot-end-marker
enable secret 5 $1$lC3V$eShhVLFZQqb2inIdLkRDF0
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool labuser
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 8.8.8.8
no ftp-server write-enable
interface FastEthernet0/0
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface Serial0/0/0
 no ip address
 shutdown
 clockrate 2000000
interface Serial0/0/1
 no ip address
 shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.254
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit any
control-plane
line con 0
line aux 0
line vty 0 4
 password cisco
 login
scheduler allocate 20000 1000
end
46 Replies 46
post the configs of all your routers...
R2 gets internet connection from home network.
R1
hostname R1
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$GmPH$sQ0WE0JzfH3xtD59VY59C/
no aaa new-model
memory-size iomem 10
dot11 syslog
ip source-route
ip cef
archive
log config
hidekeys
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
no ip address
shutdown
clock rate 2000000
ip address 11.0.0.1 255.0.0.0
ip forward-protocol nd
ip route 11.0.0.0 255.0.0.0 11.0.0.2
ip route 12.0.0.0 255.0.0.0 11.0.0.2
ip route 192.168.1.0 255.255.255.0 11.0.0.2
ip route 192.168.3.0 255.255.255.0 11.0.0.2
ip route 192.168.4.0 255.255.255.0 11.0.0.2
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
end
R2
Current configuration : 1662 bytes
! Last configuration change at 19:39:50 UTC Wed May 23 2018 by
version 15.1
hostname R2
boot-start-marker
boot-end-marker
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain name sanelccent.org
license udi pid CISCO2811 sn FCZ094871GQ
username sanel privilege 15 secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
redundancy
ip address 192.168.1.88 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
ip address 192.168.3.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip address 12.0.0.1 255.0.0.0
ip nat inside
clock rate 2000000
ip address 11.0.0.2 255.0.0.0
ip nat inside
clock rate 2000000
no ip http server
ip route 11.0.0.0 255.0.0.0 11.0.0.1
ip route 12.0.0.0 255.0.0.0 12.0.0.2
ip route 192.168.2.0 255.255.255.0 11.0.0.1
ip route 192.168.4.0 255.255.255.0 12.0.0.2
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login local
transport input all
end
R2#
R3
R3#show run
Current configuration : 1131 bytes
version 12.3
hostname R3
boot-start-marker
boot-end-marker
enable secret 5 $1$pBLN$mnP43U.Yl7b82hnJOxoBA.
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip address
shutdown
duplex auto
speed auto
ip address 192.168.4.1 255.255.255.0
ip nat inside
duplex auto
speed auto
no ip address
shutdown
clockrate 2000000
ip address 12.0.0.2 255.0.0.0
ip classless
ip route 11.0.0.0 255.0.0.0 12.0.0.1
ip route 12.0.0.0 255.0.0.0 12.0.0.1
ip route 192.168.2.0 255.255.255.0 12.0.0.1
ip route 192.168.3.0 255.255.255.0 12.0.0.1
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
end
R3#
I had problems posting R2 config because system didn't like some lines and blocked it as spam. I believe it was ssh config so I had to remove it. That's why R2 config is not complete, but I believe it should be enough.
on R2 (the middle router that does the NAT), change:
to:
ip nat inside source list 101 interface FastEthernet0/0 overload
access-list 101 deny ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 deny ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 deny ip 192.168.4.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 permit ip any any
hi
I have changed but still can't access from telnet or ping from my home network 192.168.1..  to 192.168.2 ,192.168.3 and 192.168.4 networks.
on your translating router, R2, change access list 1 from:
to
access-list 1 permit 11.0.0.0
access-list 1 permit 12.0.0.0
access-list 1 permit 192.168.2.0
access-list 1 permit 192.168.3.0
access-list 1 permit 192.168.4.0
Allowing anything is never a good idea, since it translates the outgoing interface as well...
i have changed but still can't access (ping or telnet) 2,3 and 4 networks from my home network 192.168.1..
