05-16-2018 08:52 AM - edited 03-08-2019 03:02 PM
I'm trying to setup my first home lab but I'm having an issue with telnet from my home network. I have successful connected an router 2811, switch 3560v2 and an pc1. 2811 gets internet access form my home router (netgear) and switch and pc1 gets access through 2811. I can ping 2811 from pc1(192.168.2.2) and have access through telnet. When I try to telnet from pc2(192.168.1.2) to 2811 it doesn't work, however I can ping 2811 and I get answer but no telnet connection. Thank you in advance!
Here is config print:
Solved! Go to Solution.
06-01-2018 02:17 AM
Almost done :). Everything works fine with windows firewall disabled. When enabled telnet doesn't work. I have tried to add custom rule to windows firewall but it doesn't work.
netsh advfirewall firewall add rule name="Allow Inbound Telnet" dir=in program= %SystemRoot%\System32\tlntsvr.exe remoteip=localsubnet action=allow
netsh advfirewall firewall add rule name="Allow Outbound Telnet" dir=out program=%SystemRoot%\System32\telnet.exe protocol=tcp localport=23 action=allow
06-01-2018 04:49 AM
