Telnet issue
vsabariraja
Community Member
I connected 1941 router with 2960 switch via trunk link and I want to access the switch with telnet from the router. what shall I do for this and how can I assign ip address for both router and switch to do the telnet or if any other solution is there????
  Okay, your configuration looks good to me. What we are going to do is as follows:
Assuming that we want to use VLAN-99 for switch management.
Cisco 2960 Switch. Hope you already correctly configured the trunk port(At least allow vlan 4 ,5 and 99)connected Fast0/0 on C1941.
For example
Switch(conf)#vlan 99
Switch(conf)#interface vlan 99
Switch(conf-if)#ip add 172.31.99.2 255.255.255.0   ,  You can change it to what you want.
Switch(conf-If)#no shut
Switch(conf)#ip default-gateway 172.31.99.1           , C1941's IP address
Swicth(conf)#line vty 0 15
Switch(conf-line)#password 0 cisco123
Switch(conf-line)#login
Switch(conf)#enable password 0 cisco1234
Assuming that you're going to use Fast0/24 on Switch to connect C1941
Switch(conf)#vlan 4
Switch(conf)#vlan 5
Switch(conf)#interface Fa0/24
Switch(conf-if)#switchport mode trunk
Switch(conf-if)#no shut
Cisco 1941 Router
For example
interface FastEthernet0/0.99
encapsulation dot1Q 99
ip address 172.31.99.1 255.255.255.0
     Please get back and let us know how things work out.
HTH,
Toshi
7 Replies 7
   Yes you can do. Please post current configuration on both devices.
HTH,
Toshi
version 12.2
service timestamps debug uptime
service timestamps log datetime localtime
service password-encryption
logging buffered 20480 debugging
logging monitor informational
enable secret 5 $1$9Xi/$a8C4dDrDrBO2y65dO3Zuz1
ip subnet-zero
no ip source-route
no ip domain-lookup
no ip bootp server
ip cef
isdn switch-type basic-net3
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip address
ip accounting output-packets
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 4
ip address 172.31.73.1 255.255.255.240
interface FastEthernet0/0.2
encapsulation dot1Q 5
ip address 172.31.73.17 255.255.255.240
interface Serial0
bandwidth 64
ip address 172.31.126.30 255.255.255.252
encapsulation ppp
router eigrp 100
network 172.31.0.0
auto-summary
ip classless
ip tacacs source-interface FastEthernet0
no ip http server
access-list 5 permit 172.16.4.56
access-list 5 permit 172.16.4.57
tacacs-server host 172.16.4.58
tacacs-server host 172.16.4.59
tacacs-server directed-request
snmp-server community kanbetac1dnys RO 5
snmp-server community tideciffoetaroproc RW 5
snmp-server enable traps tty
snmp-server host 172.16.4.56 kanbetac1dnys
snmp-server host 172.16.4.57 kanbetac1dnys
line con 0
password 7 131742561B030A6E6A322D
line aux 0
line vty 0 4
password 7 13061E010803
login
no scheduler allocate
end
These are all the router configuration and there is no configuration for switch, have to configure
I didn't see any lan configuration. We need to get enough information to help you.
Toshi
just now updated it. kindly review once again
For example
Switch(conf)#vlan 4
Switch(conf)#vlan 5
Cisco 1941 Router
For example
HTH,
Toshi
ya its working nice dude thanks a lot
    My pleasure
Toshi
