Telnet Issue
Tarunkumar Vyas
Level 2
Level 2
I am having cisco 3750 switch, after config line vty (Telnet) in four stack all are working fine only one stack telnet is not working.
i am able to ping Mgmt vlan IP.
Switch telnet config is ....
username cisco privilege 15 password 0 cisco
vlan 1521
name MGMT_VLAN
Int vlan 1521
ip add 192.168.10.10 255.255.255.0
line con 0
password cisco
login local
line vty 0 4
exec-timeout 0 0
password cisco
login local
line vty 5 15
exec-timeout 0 0
password cisco
login local
I have tryed to remove exec-timeout command
type "no exec-timeout" ( but unable to remove, after "save" type  "show run" again exec-timeout 0 0 comes under line vty, even i have changed exec-timeout 3 0 but no luck )
cadet alain
exec-timeout 0 0  and no exec-timeout have the same effect that is your sessions won't timeout under the lines.
It shouldn't prohibit you from telnetting into the device now if you issued no exec then you disabled access to the line( but it would show as no exec in the show run).
Alain
so  what could be the solution for this, i have given switch config related to telnet.
