telnet only works when there are two sessions?
Rich Mauger
We have several 3750X switch stacks that have suddenly started requiring two active telnet sessions to do anything with the stack. Very simple example, but applies to all aspects of switch administration:
Session 1 - issue "sh int statu" command (carriage returns and output stops)
Session 2 - issue same "sh int statu" command (carriage returns and output stops and session 1 now shows the output from the session 1 initial command)
This makes switch administration a real challenge. No config changes to the stack(s), just started happening one day...
Model#  WS-C3750X-48PF-L
SW Image: c3750e-universalk9-mz.150-2.SE5.bin
H/W Version: 3
Reza Sharifi
You are are probably encountering a bug in the version of IOS you are running.
Open a ticket with TAC.  They probably recommend an upgrade.
Reza Sharifi
