Telnet protocol uses default gateway?
pfrancis3
Level 2
Level 2
Hello, someone told me if you Telnet in to a layer 3 switch, it will need to be configured with the "default gateway x.x.x.x" command.
Even if you have the command "ip route 0.0.0.0 0.0.0.0  x.x.x.x", Telnet will not use this.
Instead Telnet only uses the "default gateway x.x.x.x" command to route telnet back to the telnet originator.
Is this correct ?
Thanks for any clarification.
Tagir Temirgaliyev
if your client computer is in the same subnet so you do not need "default gateway x.x.x.x" command and you do not need command "ip route 0.0.0.0 0.0.0.0  x.x.x.x"
if your client computer is NOT in the same subnet so for 3750 layer 3 switch you do  need command "ip route 0.0.0.0 0.0.0.0  x.x.x.x" and "ip routing".
3750 layer 3 switch not accepts command "default gateway x.x.x.x"  after  "ip routing"
Hello
@ ttemirgaliyev         "3750 layer 3 switch not accepts command "default gateway x.x.x.x"  after  "ip routing"
I have to disagree  - the switch WILL accept the ip default-gateway command however it the WILL be ignored as long as ip routing is enabled
res
Paul
Kind Regards
Paul
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
"Is this correct?"
No.
