Telnet!!!
examples20001
Hi All,
I have 2 Catalyst 4506 switch and I upgraded our server segment speed from 100 mgps to 1000 mbps for 30 ports in the catalyst 4506 switch.
No other config was changed.
Now I am not able to access the both switch thru telnet, but access thru console it is ok. what can be the reason?
Edison Ortiz
Can we see the switch config and tell us what subnet you are telneting from.
Are you able to ping the switch management IP ?
