Temperature heat output on stack switches in cab
Deano
Hi all,
I have 7 x Cisco WS-C3750-24PS-P switches stacked in a cabinet. How do I calculate the overall temperature / heat output coming from the cabinet?
Kind Regards
Dean
Julio E. Moisa
Im not really sure whether Im understanding the question, but have you tried using: show env all command?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
Thanks for replying and your help.
We are fitting new air conditioning and the air con company have asked what is the overall / total heat output from each cabinet.
So each switch is generating heat and we have 7 x cisco 3570 24-port switches in each cabinet.
How do we get the overall / total heat output from each cabinet?
Kind Regards
Dean
Joseph W. Doherty
I recall (?) datasheets sometimes show BTU generated (for max load?). If you find/take that value and multiply by seven, you should have a BTU rating.
Hi Joseph,
Great, thanks I found it.
Description Specification
Model Cisco Catalyst 3750 Series Maximum Total Output BTU
Power Supply Rated Maximum 3750-24PS 495W 426 BTU/hour
Measured 100% Throughput Power Consumption 3750-24PS 57W 194 BTU/hour
