Temperature readings and threshold
Hi, i have a few questions on temperature readings:
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.04.00.SG RELEASE SOFTWARE (fc3)
I see the following interesting readings, the first one is that i get a warning of a reading under the 1st threshold.
I see this on a lot of 4500's in the field, i assume its a cosmetic bug, i could not find anything in the buglist concerning this platform, i did see a few bugs on the cat6500 platform. And yes.. the room is on the warm side.
Could this be a rounding down issue?
GHZ-SER090-AS-01#sh env temperature
Module Sensor                     Temperature          Status
1      air inlet                  44C (45C,60C,70C)         warning
1      air outlet                 42C (61C,76C,86C)              ok
2      air inlet                  44C (45C,60C,70C)         warning
2      air outlet                 42C (61C,76C,86C)              ok
2nd, why is the outlet temp cooler than the inlet temp.
1      air inlet                  25C (45C,60C,70C)              ok
1      air outlet                 23C (61C,76C,86C)              ok
2      air inlet                  22C (45C,60C,70C)              ok
2      air outlet                 21C (61C,76C,86C)              ok
Another switch.
1      air inlet                  29C (45C,60C,70C)              ok
1      air outlet                 28C (61C,76C,86C)              ok
2      air inlet                  29C (45C,60C,70C)              ok
2      air outlet                 27C (61C,76C,86C)              ok
Anyone any ideas?
Thanks.
With regards,
Thijn
0 Replies 0
