Ten Gigabit interface can not count bit rate.
Oleg Gnedykh
Hi People!
I've got Cisco 7609 with WS-X6708-10GE (8x10Ge)
And one port (te9/4) from it have zero bit rate counters, but all the rest of it are very good.
BTW: I can see traffic if read it by SNMP.
CUT
sh int te9/4
TenGigabitEthernet9/4 is up, line protocol is up (connected)
Hardware is C6k 10000Mb 802.3, address is 001b.0de5.2980 (bia 001b.0de5.2980)
  Description:
  Internet address is x.x.x.x/30
MTU 9216 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 0/255, rxload 0/255
Keepalive set (10 sec)
Full-duplex, 10Gb/s
Transport mode LAN (10GBASE-R, 10.3125Gb/s)
input flow-control is off, output flow-control is off
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 05:04:34
Input queue: 0/75/13/13 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
L2 Switched: ucast: 45807 pkt, 5510959 bytes - mcast: 6277 pkt, 493842 bytes
L3 in Switched: ucast: 4181386438 pkt, 3075459119773 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 4171812456 pkt, 3461584748808 bytes mcast: 0 pkt, 0 bytes
4180503416 packets input, 3074832305731 bytes, 0 no buffer
Received 6274 broadcasts (0 IP multicasts)
0 runts, 885 giants, 0 throttles
0 watchdog, 0 multicast, 0 pause input
4170654636 packets output, 3464391999669 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
CUT2
sh int te9/6
TenGigabitEthernet9/6 is up, line protocol is up (connected)
Description: LIP-Te6/5
reliability 255/255, txload 101/255, rxload 124/255
Full-duplex, 10Gb/s
Input queue: 0/75/29494/26946 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 4867340000 bits/sec, 752425 packets/sec
5 minute output rate 3991572000 bits/sec, 629062 packets/sec
L2 Switched: ucast: 8288830 pkt, 687208565 bytes - mcast: 1021125 pkt, 80453420 bytes
L3 in Switched: ucast: 338785153739 pkt, 239737259157798 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 509158770601 pkt, 429164728667687 bytes mcast: 0 pkt, 0 bytes
338783357015 packets input, 239728195542054 bytes, 0 no buffer
Received 1021128 broadcasts (0 IP multicasts)
0 runts, 3565918579 giants, 6 throttles
509105316251 packets output, 435452912251165 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
nkarpysh
I think this is answered here https://supportforums.cisco.com/message/3470780#3470780. For the sake of documenting. Rot cause was CSCsz18634. Credits go to Eugene Khabarov.
HTH,
Niko
