test etherchannel load-balance on 4948
prekursor
is there a way to see where the traffic will go on cat 4948 in the etherchannel.
i could not find test etherchannel load-balance command.
Roberto Salazar
Level 8
Level 8
Hi, here is what you are looking:
show platform software etherchannel port-channel 1 map x.x.x.x y.y.y.y
Switch#show platform software etherchannel port-channel 1 ?
map Map given parameters to a port in the channel
| Output modifiers
Switch#show platform software etherchannel port-channel 1 map ?
ip Ip address
l4-port TCP/UDP port numbers
mac Mac address
Switch#show platform software etherchannel port-channel 1 map 1.1.1.1 ?
% Unrecognized command
Switch#show platform software etherchannel port-channel 1 map ip ?
A.B.C.D Source/Destination Ip address
Roberto Salazar
Level 8
Level 8
| Output modifiers
ip Ip address
mac Mac address
awesome
you are the man
