Test Multicast routing with 1801
ealtun
hi,
I would like test multicast routing with cisco1801.
i create 2 Vlan. Vlan 200 (192.168.200.x) affect Fastethernet 1, Vlan 130 (192.168.130.x) Fastethernet 5.
Version IOS is : adipservice-k9 124-9.t1
  1. ip multicast-routing
#int Vlan 130
ip address 192.168.130.254 255.255.255.0
Ip pim dense-mode
#int Vlan 200
Ip address 192.168.200.254 255.255.255.0
Ip pim dense-mode
I used VLC for my test.
When i connect source (224.10.10.10) and recever ( Udp://@224.10.10.10:1234), that's ok!
But, source is on the Vlan 200 and reicever on the Vlan 130, is not good!
I test with "sparse-mode", i have same problem.
Tank you for help!
John Blakley
What do you mean it's "not good?" What is it doing or not doing? Is it that the quality is bad or does it not work at all?
HTH, John *** Please rate all useful posts ***
ealtun
It not work at all!
I think the problem it s VLC.
You know another software like VLC ?
Thank you
