Cisco Nexus 7010 question.
narciso.lazo
Hello everybody,
What is the exact command in restoring the running-config on a Nexus 7010. Is it thesame commnd / procedure as the Cisco IOS?
Please help and Thank you in advance.
--chie
Pawan Sharma
Please try
rollback running-config {checkpoint cp name | running-config | startup-config | file filename} {atomic | best-effort | stop-at-first-failure}
Example: rollback running-config checkpoint cp-running-config-known-good-2010-03-22 atomic
To see the status of rollbacks:
show rollback log
You can also clear out the checkpoint history and files, use the command with caution.
clear checkpoint database
Pawan Sharma
http://www.ebrahma.com
Pawan Sharma
https://itgears.io
Thank you Pawan,
so this rollback command is applicable also when trying to restore the running-config from a TFTP server or some other outside source? Thank's again.
--chie
Yes, After rollback running-config command you can navigate throught the options available. "File" is one of them, which can be used to solve your purpose.
Pawan Sharma
Pawan Sharma
https://itgears.io
