Test Tranceiver
Ibrahim Jamil
Level 6
Level 6
Hi Folks
1)is there any method to test if the transceiver GLC-SX-MM inside the 3560 is faulty or isn�t function properly ,through the CLI
5 Replies 5
jonathanaxford
Level 3
Level 3
I am not aware of any CLI commands that will perform a test of a GBIC - do you suspect that the module is faulty? Are you experiencing errors etc?
Cheers
Jonathan
Reza Sharifi
You can try this command, but it is not really useful, because the interface has to be in
up and up mode, which defits the purpose.
test interfaces gigabitEthernet x/x/xx
If the interface is not up this is the output
Switch-D#test interfaces gigabitEthernet 1/0/46
No IP address for GigabitEthernet1/0/46.
Skipping...
1 interfaces: 0 passed, 0 failed, 0 skipped, 1 untestable
Switch-D#
Leo Laohoo
Try the simple command of "sh inventory".  If you get an output that means that the appliance can "see" the component.  Other than that you'll need to get an OTDR.
what is the   OTDR
OTDR stands for Optical Tim Domain Reflectometre.  The TDR itself is a method of testing small electrical mumbo-jumbo of your copper lines.  The Optical TDR will test laser-related links like fibre optic.
