Bookmark
Subscribe
1782
TFTP a folder from flash on ASA?
Andy White
Level 3
Level 3
I have no problem copying files from my ASA to and from the flash, but how do you copy a folder?
I have tired to tftp this sdesktop folder so I can copy it to another ASS, but I gert an access denied error:
  187  8192        Jul 15 2013 15:01:21  sdesktop
  188  1621        Jul 16 2013 10:22:06  sdesktop/data.xml
copy flash:/sdesktop tft
ASA# copy flash:/sdesktop tftp://192.168.9.11
Source filename [sdesktop]?
Address or name of remote host [192.168.9.11]?
Destination filename [sdesktop]?
%Error reading disk0:/sdesktop (Permission denied)
ASA#
5 Replies 5
cadet alain
the tftp protocol doesn't support transferring folders,only files.I think that ftp does though.
Alain
I think your correct about the folder issue cadet. I've never really had a need to tftp a folder to an ASA before, so I've never really tried it. I've only tftp'd configuration, and images for upgrades etc.
I can transfer the file within the folder, can I create a fodler called sdesktop and then tftp into it?  If so what is the command?
Hello
mdir flash:/sdesktop
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
I would assume you could do
mdir disk0:/[Directory-Name] as well etc etc
