TFTP: error code 1 received - 18025
rjust1965
hi all,
i got a strange error on a 3750. i just do a:
copy running-config startup-config
here is the output:
Destination filename [startup-config]?
Building configuration...
[OK]
here is the version:
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
here is the memory information:
Directory of flash:/
2 -rwx 9204473 Mar 1 1993 01:09:42 +01:00 c3750-ipbasek9-mz.122-46.SE.bin
3 -rwx 17872 Mar 1 1993 01:25:06 +01:00 startup-config1
4 -rwx 4120 Oct 27 2009 12:19:36 +01:00 multiple-fs
5 -rwx 736 Mar 1 1993 01:00:33 +01:00 vlan.dat
6 -rwx 9082 Oct 27 2009 12:19:36 +01:00 private-config.text
8 -rwx 18591 Oct 27 2009 12:19:36 +01:00 config.text
15998976 bytes total (6741504 bytes free)
Directory of system:/
2 -r-- 0 <no date> default-running-config
4 dr-x 0 <no date> memory
1 -rw- 19926 <no date> running-config
3 dr-x 0 <no date> vfiles
No space information available
Directory of tmpsys:/
No files in directory
Directory of nvram:/
484 -rw- 18591 <no date> startup-config
485 ---- 9082 <no date> private-config
1 -rw- 1736 <no date> ifIndex-table
2 -rw- 579 <no date> IOS-Self-Sig#3232.cer
4 ---- 12 <no date> persistent-data
524288 bytes total (492467 bytes free)
so where's the problem ?
regards Reinhold
6 Replies 6
lgijssel
Level 9
Level 9
Could you please post the output from:
sh run | inc tftp
regards,
Leo
hi Leo,
thanks for answer.
the output is empty.
regards Reinhold
Reinhold,
You normally get this error when you are pointing to a miss configured TFTP server.
Just curious, does “wr” gives you the same results?
Reza
hi Reza,
yes, the output is the same. when i tftp to my server it works without problems.
wr
[OK]
switch#copy run tftp:
Address or name of remote host []? ip
Destination filename [switch-confg]?
19926 bytes copied in 1.199 secs (16619 bytes/sec)
thanks, Reinhold
Perhaps your flash is corrupted or set to write only.
Please check the contents of the config-register
I also noticed that you installed an image via a direct copy from tftp to flash, otherwise the .bin would be in sub-folder.
I would recommend to erase the flash, format it and reinstall it using the archive command:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00804799d7.shtml
regards,
Leo
hi Leo,
Configuration register is 0xF
i changed a little bit in the config and downloaded it to my server and it was the changed one. so the flash should be ok. don't you think ?
regards Reinhold
