10-26-2009 01:02 PM - edited 03-06-2019 08:18 AM
I am having a problem getting allowed trunks to show up in my configuration
I am setting up the portchannels on the 6513 to trunk. I have them set for encap dot1q, switchport, and switchport mode trunk.
When I go to add the switchport trunk allowed vlan add 2,100,110... it doesnt get added.
When I issue the show interface port-channel 6 trunk it shows that no vlans are allowed?
Probably an easy question that I am just missing.
The port channel is shut down but is not yet connected to the other switch so it is admin up protocol down.
James
Solved! Go to Solution.
10-26-2009 03:57 PM
You could try removing all vlans but those 3 and see what happens
switchport trunk allowed vlan remove 1,3-99,101-109,111-1025 etc...
10-26-2009 03:09 PM
possible example of syntax:
Port-channel64
switchport
switchport trunk allowed vlan 123, 124, 125
switchport nonegotiate
no ip address
10-27-2009 05:30 AM
That's exactly the command set I used. Didnt show up in the running config.
10-27-2009 07:32 AM
Thanks for the feedback. Perhaps if you provide us a copy of your running config we can see something missing... i.e. port shutdown or no vlan in vtp domain database.......
10-26-2009 03:26 PM
Have you tried allowing the vlans on the interfaces that belong to the port-channel? Make sure they're all the same config.
10-27-2009 05:32 AM
Shouldn't have to do that really. That's kind of the purpose of the portchannel in the first place. I will have about 16 different port channels on each 6513. Largest portchannel will be 4 ports. I'd prefer to just configure the portchannel with the VLANs as opposed to all the physical ports.
10-26-2009 03:57 PM
10-27-2009 05:33 AM
Interesting thought. Will give it a shot. But right now it says I have NONE allowed. Maybe a little reverse psychology will do the switch good!
10-27-2009 09:09 AM
Glen you were definitely on the right track. I brought up the other side of the portchannel so I could troubleshoot.
What it ended up being is that on CoreA I had VLANs 1-4094 allowed and on CoreB I had only the VLANs I wanted to allow in the config.
I remembered that some point in the early troubleshooting of this issue that I put the switchport trunk allowed VLAN add all command. Unfortunately for Cisco users, this actual command does not show up in the running config.
I ended up doing a switchport trunk allowed vlan none command then issued the switchport trunk allowed vlan 2,100,110 and now only those correct VLANs are on the trunk.
Thanks for everyone's help. Now I am off to configure the HA for the FWSM on the two Chassis. I am sure you will hear from me again soon.
Five stars to Glen! Thanks.
James
