TFTP Server help
paul dungey
Level 3
Level 3
How do i go about setting up a TFTP server from laptop to Cisco ws-C3750 48P Switch, I need to pull the image off the switch and place it on an other switch that has a corrupt image, The switch which is corrupted is the same as above Cisco ws-C3750 48P.
Step by step.
Paul
Oleksandr Nesterov
Hi Paul
1. you need to setup tftp server which will be reachable from both switches:
You can use following program:http://tftpd32.jounin.net/
Then you need to upload image from the switch to TFTP server and then diwload it to the corrupted switch.
You can refer to the following video.
http://www.youtube.com/watch?v=4g4E2n1tJFw
http://www.youtube.com/watch?v=FuULscR9MEo
HTH,
Alex
