The IE2000 is an infrared power supply
sserfas579
Hi there,
Is it necessary to connect the Cisco IE2000's two DC inputs to the same power supply? In spite of the fact that DC-A and DC-B are not fully redundant, each has its own internal power supply. This would allow DC-A and DC-B to be powered by the same external power supply... It is greatly appreciated that you responded to me. The power supply consists of two separate units. A switch can be powered by one or two sources. In the event that both power sources are active and the higher voltage power source is on, both power sources draw power from each other. During a power outage, the switch remains powered by the other power source. Each power supply should be connected to an independent power source in redundant power systems. Failing to do this might result in a total power outage due to an electrical fault in the wiring or a circuit breaker trip.
Soichiro-Ono
Hello.
Please refer my post.
Re: An IE2000 Dual Power Supply - Cisco Community
Regard,
If you found this post helpful, please give it Helphul.
If my answer solved your problem, click "accept as solution" so that others can benefit from it.
有用な回答だと思われる際には いいね! をクリックして頂けると幸いです。
回答があなたの問題を解決した場合、解決済みをクリックしてください。
