The IP Routing Process for VLAN's?
mwest1956
I have the CCNA Study Guide third edition. Chapter five, page 254 has a description of the ip routing process.  It descripes the ip routing process using two nodes on different subnets and a router.
We've recently deployed VLAN's, so I'm asking if I replace the router with a switch in the description, if the principles would still apply?  I'm also asking if someone knows of a link that describes the ip routing process when using a VLAN?  I'm looking for documentation that's similar to what's in the book, but modernized.
tia
eduardopozo56
I do not have the book but i will try to help:
Switches dont do inter-vlan routing (Unless you are using a layer 3 switch) so if you are have different Vlans configured on your switch and want them to comunicate each other without a router you cant.
If you have a router the same principles apply to normal routing, remember that VLANS are just a way of dividing your clients, so your VLANS configured on your subinterfaces will appear directly connected on your ip route table. For example:
VLAN 10: 192.168.10.0
VLAN 20: 192.168.20.0
VLAN 30: 192.168.30.0
You have vlan 10 and 20 locally on a lan interface (They will be directly connected on your ip route) but vlan 30 is reachable thru a serial interface (ppp or frame relay) you would use:
ip route 192.168.30.0 255.255.255.0 serialx/x
