Theoretical question about stack
aukhadiev
Suppose we have a stack of 6 switches (Catalyst 3850) with cross-stack EtherChannel to core as uplink... Assume that the switch 5 receives a frame on its access port with the destination address to core... Assume that ether-channel load-balance algorithm decides that the given frame should go through interface Te1/1/1...
Question, is the stacking technology (StackWise-480) "smart enough to understand" that the shortest path from the switch 5 to interface Te1/1/1 interface is through the switch 6, not throuth the switch 4?
Please, see attached picture...
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I haven't seen much documentation about how any of the Cisco stacks decide which stack port to use, but I recall reading something about it might just be based on stack port load.
