Threshold_Violation error messages
Tarun Arora
Frequent Visitor
Frequent Visitor
Hi guys,
I recently noticed company core switch cisco 4507 generating the below error messages from the 10gig module.
*Jan 28 22:16:10.752: %SFF8472-5-THRESHOLD_VIOLATION: Te3/2: Rx  power low alarm; Operating value: -12.7 dBm, Threshold value: -12.4 dBm.
*Jan 28 22:16:03.004: %SFF8472-5-THRESHOLD_VIOLATION: Te7/2: Rx  power low warning; Operating value: -10.4 dBm, Threshold value:  -8.4  dBm.
Interface ten3/2 is interconnecting another 4507 within the same network cabinet.
Interface ten7/2 is interconnecting a different site distribution switch that is 400meters away.
Anyone who can assist.???
12 Replies 12
Ankur Arora
Level 7
Level 7
Tarun,
What is the SFP model.
Issue the following commnds:
sh int ten3/2 transceiver detail
sh int ten7/2 transceiver detail
sh idprom int ten3/2
sh idprom int ten7/2
Show interface ten3/2 transceiver threshold violations
Show interface ten7/2 transceiver threshold violations
This error message denotes that both the ends are recieving less power than the minimum operating value.
Ankur
"Please rate the post if found useful"
thanks Ankur,
Below is the output of sh commands,
CORE1#sh int ten3/2 transceiver detail
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
                              High Alarm  High Warn  Low Warn   Low Alarm
          Temperature         Threshold   Threshold  Threshold  Threshold
Port       (Celsius)          (Celsius)   (Celsius)  (Celsius)  (Celsius)
Te3/2       28.1                74.0        70.0         0.0       -4.0
           Voltage            Threshold   Threshold  Threshold  Threshold
Port       (Volts)            (Volts)     (Volts)    (Volts)    (Volts)
Te3/2      0.00                   N/A         N/A         N/A        N/A
           Optical            High Alarm  High Warn  Low Warn   Low Alarm
           Transmit Power     Threshold   Threshold  Threshold  Threshold
Port       (dBm)              (dBm)       (dBm)      (dBm)      (dBm)
Te3/2       -2.5                 2.9         0.4        -6.5      -10.5
           Receive Power      Threshold   Threshold  Threshold  Threshold
Te3/2      -12.7                 2.9         0.4        -8.4      -12.4
CORE1#
CORE1#sh int ten7/2 transceiver detail
Te7/2       32.8                74.0        70.0         0.0       -4.0
Te7/2      3.27                   N/A         N/A         N/A        N/A
Te7/2       -2.1                 2.9         0.4        -6.5      -10.5
Te7/2      -10.5                 2.9         0.4        -8.4      -12.4
#sh idprom int ten3/2
X2 Serial EEPROM Contents:
Non-Volatile Register (NVR) Fields
X2 Version                           :0x1E = MSA Version 0x1E
NVR Size in bytes                    :0x100
Number of bytes used                 :0x100
Basic Field Address                  :0xB
Customer Field Address               :0x77
Vendor Field Address                 :0xA7
Extended Vendor Field Address        :0x100
Reserved                             :0x0
Transceiver type                     :0x2 =X2
Optical connector type               :0x1 =SC
Bit encoding                         :0x1 =NRZ
Normal BitRate in multiple of 1M b/s :0x2848
Protocol Type                        :0x1 =10GbE
Standards Compliance Codes :
10GbE Code Byte 0                    :0x0 =10GBase-LRM
10GbE Code Byte 1                    :0x0
SONET/SDH Code Byte 0                :0x0
SONET/SDH Code Byte 1                :0x0
SONET/SDH Code Byte 2                :0x0
SONET/SDH Code Byte 3                :0x0
10GFC Code Byte 0                    :0x0
10GFC Code Byte 1                    :0x0
10GFC Code Byte 2                    :0x0
10GFC Code Byte 3                    :0x0
Transmission range in 10m            :0x16
Fibre Type :
Fibre Type Byte 0                    :0x1 =MM, Generic
Fibre Type Byte 1                    :0x0 =Unspecified
Centre Optical Wavelength in 0.01nm steps - Channel 0 :0x1 0xFF 0xB8
Centre Optical Wavelength in 0.01nm steps - Channel 1 :0x0 0x0 0x0
Centre Optical Wavelength in 0.01nm steps - Channel 2 :0x0 0x0 0x0
Centre Optical Wavelength in 0.01nm steps - Channel 3 :0x0 0x0 0x0
Package Identifier OUI  :0xC09BE0
Transceiver Vendor OUI  :0x3E800
Transceiver vendor name :CISCO-EXCELIGHT
Part number provided by transceiver vendor       :SDX4101LM-C1-M
Revision level of part number provided by vendor
Vendor serial number           :ECL131600C3
Vendor manufacturing date code :200904274H
Current Reference :
5V Stressed Environment Reference 100 percent=1A   :0x0
3.3V Stressed Environment Reference 100 percent=2A :0x4
APS Stressed Environment Reference 100 percent=2A  :0x2
Normal APS Voltage :0x4
Digital Optical Monitoring Capability Byte  :0xC7
Digital Optical Monitoring                  :Implemented
Low Power Start-up(LPS) Mode Capability Bit :0x1
Reserved             :0x0
Basic Field Checksum :0x23
Customer Writable Area :
  0x00: 58 32 2D 31 30 47 42 2D 4C 52 4D 20 20 20 20 20
  0x10: 20 56 30 31 20 45 43 4C 31 33 31 36 30 30 43 33
  0x20: 31 30 2D 32 33 36 38 2D 30 31 20 20 41 30 20 20
Vendor Specific :
  0x00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x10: 00 00 00 00 00 00 00 00 00 8A 33 13 43 00 00 00
  0x20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x30: 00 00 02 00 0B 5F C2 DB 77 84 26 70 B7 35 04 D1
  0x40: 39 7C 79 54 98 00 00 00 00 00 00 00 00 00 48 D5
  0x50: 90 7C 15 DB 11 9D 00 CC 20
CORE1#
CORE1#sh idprom int ten7/2
Reserved                             :0x0
Fibre Type :
Package Identifier OUI  :0xC09820
Transceiver Vendor OUI  :0x3400A80
Transceiver vendor name :CISCO-OPNEXT,INC
Part number provided by transceiver vendor       :TRT5002EN-SMC-6
Revision level of part number provided by vendor :A1
Vendor serial number           :OPB17350162
Vendor manufacturing date code :2013091900
Current Reference :
3.3V Stressed Environment Reference 100 percent=2A :0x1
APS Stressed Environment Reference 100 percent=2A  :0x10
Digital Optical Monitoring Capability Byte  :0xD7
Reserved             :0x0
Basic Field Checksum :0xAE
  0x10: 20 56 30 34 20 4F 50 42 31 37 33 35 30 31 36 32
  0x20: 31 30 2D 32 33 36 38 2D 30 34 20 20 41 30 20 20
Vendor Specific :
  0x00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0x10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0x20: FF FF FF FF FF FF FF FF FF 00 AA 00 A0 FF FF FF
  0x30: FF FF 02 00 11 AB 00 9B 52 D4 A1 C6 DC 79 90 A3
  0x40: 18 A9 77 2C 87 00 00 00 00 00 00 00 00 00 A1 39
  0x50: B9 6D 17 52 0D F0 27 10 FF
the sfp's are
10GBase-LRM for all the interfaces with errors messages.
Tarun,
The reason you are getting the Low power alarms on these interfaces is that
10GBase-LRM Module supports link lengths of 300m on standard single-mode fiber and supports link lengths of 220m on standard Fiber Distributed Data Interface (FDDI) grade multimode fiber (MMF) However you are using it over a distance of 400m.
You need to change the SFP to the one which supports a distance of 400m like SFP-10G-LR for single mode.
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/data_sheet_c78-455693.html
Ankur
Hi Ankur and thanks for the feedback.
One question, what impact does the error messages am getting have on my link connecting to the core switch?. Will the quality of the link be affceted.?
Tarun,
Yes indeed the quality of link is affected and there might be loss of data packets. You might also see input errors and CRC on that interface where link is connected.
Ankur
Hi Ankur,
I changed the patchcord connecting core 1 and 2 which are in the  same room and within the same network cabinet but the threshold  violation error messages still appear on that interface. Ten 3/2
Below is the output of the various show commands for this interface.Hope it helps
CORE1#
*Feb  12 02:49:27.372: %SFF8472-5-THRESHOLD_VIOLATION: Te3/2: Rx power low  alarm; Operating value: -12.6 dBm, Threshold value: -12.4 dBm.
CORE1#sh run int ten 3/2
Building configuration...
Current configuration : 158 bytes
interface TenGigabitEthernet3/2
description 10G_TRUNK TO CS-02
switchport trunk native vlan 999
switchport mode trunk
channel-group 60 mode active
end
CORE1#sh int ten 3/2 transceiver detail
Te3/2       28.0                74.0        70.0         0.0       -4.0
Te3/2       -2.4                 2.9         0.4        -6.5      -10.5
Te3/2      -12.6                 2.9         0.4        -8.4      -12.4
CORE1#
CORE1#sh idprom int ten3/2
Reserved                             :0x0
Fibre Type :
Current Reference :
Reserved             :0x0
Vendor Specific :
CORE1#Show interface ten3/2 transceiver
If device is externally calibrated, only calibrated values are printed.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
                                 Optical   Optical
           Temperature  Voltage  Tx Power  Rx Power
Port       (Celsius)    (Volts)  (dBm)     (dBm)
Te3/2        28.5       0.00      -2.4      -2.1
Tarun,
The fibre that you are using, is it Multi mode or Single mode?
Ankur
Ankur,
the fiber patch cord i am using is multimode.
Tarun,
With Multimode you will need the Mode Conditioning Patch (MCP) cable when using 10GBase-LRM.
Are you using it? if not, you should use it.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/product_bulletin_c25-530836.html
Ankur
Hi Ankur,
Does cisco have any software that helps in deploying configurations on multiple switches or routers over the network.?
How can i acquire it or purchase and what is it called.Does the software also deploy configurations on non-cisco devices?
Hi Ankur,
kindly assist with the below issue. i will appreciate.
we have some new cisco air cap1602e e k9 access points and they are not working with the wlan controller 2504-k9.
the controller is running ios Software Version 7.2.115.1 .looking at various blogs they  to upgrade our ios version but am wondering how to go about it .can you just upgrade to latest or is there a way to upgrade.
Below are the error messages from the AP.
*Mar  1 01:09:30.333: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 01:09:33.345: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 01:09:33.409: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.30.102.29, mask 255.255.255.0, hostname APfc99.47a3.7b4f
*Mar  1 01:09:41.333: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 01:09:51.337: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_31:ba:44'running version 7.2.115.1 is rejected.
*Mar  1 01:09:51.337: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 01:09:51.337: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 01:09:51.337: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 01:09:51.337: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.30.195.2
