Troubleshooting Routing Inter-VLAN
Hi guys,
I have a 6500 core to Layer 3 and 2960 Switch to Layer 2 where to connect the servers. Furthermore have created the next vlans:
VLAN Name                             Status    Ports
20   USER                             active
25   USER_LAB                        active
30   SERVER                         active
In the vlan 30 have a 10 servers, and create SVI to permit routing inter-vlan. My issue is that from vlan 20 and 25 reach all server except 2 servers.
ping 10.0.0.49 source vlan 20
Sending 5, 100-byte ICMP Echos to 10.0.0.49, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
I think that is problema of the configuration these servers, but anybody knows how troubleshooting this issue.
Checked for me:
1) The SVI 20 and 25 don't have ACL.
Thanks in advance!
http://networkingcontrol.wordpress.com/ #CCNP CSCO11962956
Reza Sharifi
The switch by default perform inter-vlan routing.  You don't need any ACL anywhere for the SVIs to talk to each other. Can you post the config and also post the output of "sh vlan"
prajithtr_2
could  you check and confirm the ip address of the servers are correct and status of interfaces to which the servers connected are up ,
PrajithTR
