Throughput of Cisco 3750-E
Sam Pragash
Can anyone let me know the actual throughput of Cisco 3750-E (WS-C3750E-24TD-S) Standalone switch and the throughput when stacked with 4 nos of WS-C3750E-24TD-S ?
Is WS-C3750E-24TD-S ports oversubscribed?
Sam.
Hi Sam,
It has wire rate back plane.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-e-series-switches/prod_bulletin0900aecd805bbe54.html
atalyst 3750-E Series
WS-C3750E-24TD-S
• 24 10/100/1000 ports + 2 X2-based 10 Gigabit Ethernet ports
• 64-Gbps, high-speed StackWise Plus stacking
• 68-Gbps, wire rate backplane
• Field-replaceable 265WAC power supply and fan tray
• 1 rack unit (RU) stackable multilayer switch
• IPv6
• IP Base software feature set (IPB)
Hope this helps. Please remember to always rate helpful posts.
Madhu
Thanks Madhu,
Can u tell me how it is 68Gbps Wire rate?
Sam.
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I think the 68 Gbps backplane supports the 48g port variants plus two 10g ports; i.e. 48+10+10=68.
What's a bit confusing, fabric specifications are normally "doubled" to allow for duplex ports but Cisco, in the posted spec uses the term "backplane" rather than "fabric".
Also confusing, when stacked, there's a pair of 16g stack ports too.  It's unclear whether the same backplane or fabric bandwidth is shared with those, or whether there's additional capacity to support them too.  I.e. the 3750-E might support wire rate bandwidth when used standalone but might not when stacked.
In any case, when 3750-E units are stacked, the stack ring can be a potential bottleneck.  Fortunately, besides StackWisePlus offering twice the stackport bandwidth of StackWise, it also supports (for unicast) destination stripping and also (for unicast) only puts traffic on the stack ring when it must.  Still, again, it's a potential bottleneck.  It's also a ring, not a fabric.
PS:
Besides bandwidth, you need to check a switch's PPS capacity.  I believe the 3750-E has sufficient PPS it can generally support wire rate.
However, one common problem with 2960/3560/3750 series switches is lack of RAM for deep buffering.  The 3750 series, I understand, to have 2 MB per 24 copper ports and 2 MB for the uplink ports.
The 3750 stacks are often fine for user edge ports, often not so fine for more demanding roles.
PPS:
Also believe the 3750-E is end-of-life and end-of-sale.
Dear Sam,
Do you have any more questions.
Please remeber to always rate helpful posts and mark answers which are correct.
M
