Timeout absolute problem Timeout absolute problem Timeout absolute problem
tareqrebhi
Daers,
I have a problem with ADSL connectivity that every 1 hour and 39 minutes my ADSL customers lost the connections ------ I know this is refer to timeout absolute I made no timeout absolute at my Virtual- Template but no difference.
Can I have help from you to solve the problem ?
ip name-server 55.55.65.11
ip name-server 55.55.64.11
vpdn enable
vpdn source-ip 192.168.55.55
vpdn-group 1
! Default L2TP VPDN group
description ADSL
accept-dialin
protocol l2tp
virtual-template 1
local name TARLNS
lcp renegotiation always
l2tp tunnel password 7 030752180500
interface Loopback0
ip address 55.55.64.96 255.255.255.255
no ip redirects
no ip unreachables
shutdown
interface Null0
no ip unreachables
interface FastEthernet0/0
description local ethernet
ip address 55.55.64.61 255.255.255.192
no ip redirects
no ip proxy-arp
no ip route-cache cef
no ip route-cache
duplex full
speed 100
standby timers 5 7
standby 10 ip 55.55.64.62
standby 10 preempt
interface FastEthernet0/1
description DSL-Traffic from JTC (Customer ADSL)
ip address 192.168.55.55 255.255.255.248
no ip route-cache
duplex full
speed 100
interface Virtual-Template1
description LNS-Interface
mtu 1454
ip unnumbered FastEthernet0/0
no ip redirects
no ip proxy-arp
ip tcp adjust-mss 1414
timeout absolute 70000000 50
peer default ip address pool default
keepalive 20
ppp authentication pap chap callin
ppp ipcp dns 55.55.64.11 55.55.65.11
ip local pool default 55.55.66.1 55.55.66.62
lgijssel
Level 9
Level 9
1 hr 39 mins equals 99 mins. Could also be something like 01:39:59 or 100 minutes. This is very likely a provider-configured timeout.
As this is only a partial config, my guess is that your firewall settings are blocking the re-negotiation of the connection.
regards,
Leo
but my router is not behind the firewall it is connected to my Local Telecom Carrier, any way see my output:
ADSLRouter-01#sh interfaces virtual-access 2
Virtual-Access2 is up, line protocol is up
Hardware is Virtual Access interface
Interface is unnumbered. Using address of FastEthernet0/0 (55.55.64.61)
MTU 1454 bytes, BW 622080 Kbit, DLY 100000 usec,
Encapsulation PPP, LCP Open
Open: IPCP
PPPoVPDN vaccess, cloned from AAA, Virtual-Template1
Vaccess status 0x44
Protocol l2tp, tunnel id 18369, session id 15542, loopback not set
DTR is pulsed for 5 seconds on reset
Time to interface disconnect: absolute 00:56:24
Last input 00:00:01, output never, output hang never
Last clearing of "show interface" counters 01:10:21
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 10000 bits/sec, 26 packets/sec
54525 packets input, 3778197 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
3461 packets output, 1233737 bytes, 0 underruns
0 carrier transitions
ADSLRouter-01#sh interfaces virtual-access 3
Virtual-Access3 is up, line protocol is up
MTU 1454 bytes, BW 1000000 Kbit, DLY 100000 usec,
Open: IPCP
Vaccess status 0x44
Protocol l2tp, tunnel id 31300, session id 15546, loopback not set
Time to interface disconnect: absolute 01:36:46
Last input 00:00:03, output never, output hang never
Last clearing of "show interface" counters 00:20:57
109 packets input, 8306 bytes, 0 no buffer
96 packets output, 13778 bytes, 0 underruns
