Timeout issue on ASA connections
I have a weird issue that I think I've narrowed down to being related to the timing out of connections inside my DMZ.
I was wondering first, are there any issues I should keep in mind when I start increasing the stock timeout values for conections?
Say if I double them, other than increased memory usage on my ASA, any other concerns?
Also, can anyone spot any value here that don't look default? It's from a Cisco ASA 55XX. I don't have another to compare it to.
My initial guess is my issue might be the 'half-closed' value, but I'm not sure yet.
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00
half-closed 0:10:00
udp 0:02:00
icmp 0:00:02
timeout sunrpc 0:10:00
h323 0:05:00
h225 1:00:00
mgcp 0:05:00
mgcp-pat 0:05:00
timeout sip 0:30:00
sip_media 0:02:00
sip-invite 0:03:00
sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00
uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
Thanks in advance,
Jon
dominic.caron
Level 5
Level 5
The default timeout are in this document but look's like it's all default.
You need to monitor the numbre of active connection and insure you dont max you appliance.
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/t.html#wp1540870
Good stuff. Thanks!
