i need help with my Cisco 3750, I'm trying to reset the password but cannot communicate with my switch, what am I doing wrong?
triangel69
Arumugam Muthaiah
Hi Miriam,
Please see the below procedure to change the password for the this switch,
  • Connect to Cisco 3750 with the Console Cable at it’s original settings
  • Unplug the power cable
  • Power On the switch Cisco 3750
  • Press Mode, bring it to the switch: prompt:
  • Issue the switch: flash_init
  • Issue the switch: load_helper
  • Issue switch: dir flash: (Make sure to type a colon ":" after the dir flash)
  • Then the switch file system is displayed
switch: dir flash:
Directory of flash:/ 2    -rwx  1803357                  c3500xl-c3h2s-mz.120-5.WC7.bin
4    -rwx  1131                     config.text
  • Type switch: rename flash:config.text flash:config.text.old
  • Issue the switch: boot
  • Continue with the configuration dialog? [yes/no]: N
  • At the switch prompt, type Switch> enable
  • Type Switch# rename flash:config.text.old flash:config.text
  • Copy the the configuration file into memory Switch# copy flash:config.text system:running-config
  • Overwrite the current passwords that you do not know. Choose a strong password
          Switch# conf t
          Switch(config)# enable secret
          --- To overwrite existing vty password
          Switch(config)#line vty 0 15
          Switch(config-line)#password
          Switch(config-line)#login
          --- To overwrite existing console password
          Switch(config-line)#line con 0
          Switch(config)# exit
          Switch# copy running-config startup-config
  • Switch# reload
Refer:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
Aru
Regards, Aru *** Please rate if the post useful ***
