Top Command
jkaftan
Community Member
I have a 6509 running IOS 12.2(18)SXD. I found a doc on Cisco's site that says that I should be able to run the Top command but I cannot. It does not exist. Nor does the Collect command. What am I missing here? Here is the link that tells me I should have the Top command. http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008043580b.html#wp1026365
6 Replies 6
b-ulrich
Level 6
Level 6
Hi, I have used this command sparingly, but I believe it is only available with CAT OS and not IOS, of which you are running.
jkaftan
Community Member
Yes that was what I thought too untill I did a search and found the document I referenced when I started the thread. It is a doc for configuring IOS on a 6509. It is for the verison I am running. It claims that the command should be there.
Thanks.
autobot130
Level 3
Level 3
The command is available. I just tested on a 6509/SUP720 w/ 12.2(18)SXE4. Works great, thanks for bringing it up.
I originally thought it was ONLY for CATOS, but apparently it works for both.
CATOS: show top
IOS: (2 step process)
1. collect top ....
2. wait a few secs...
3. show top counter interface report 'x'
Yes my problem is that the "collect" command is not there. Neither is "Show Top".
andrew.burns
Level 11
Level 11
Your linked document has the answer:
"Release 12.2(18)SXE and later releases support the Top N utility."
As you're only running 12.2(18)SXD you need to upgrade...
Andrew.
Well shoot! That's embarrasing. I did not catch the D of SXD. Thanks for pointing it out.
I will looking into upgrading as this will be a handy feature.
