Topology change from a portfast interface
Tauer Drumond
Hi all,
Recently, I had a topology change in my network enviroment comming from a switchport access port.
This port is configured with spanning-tree portfast command.
I assume that a switch never generates a TCN when a port configured for portfast goes up or down.
Switch says: Number of topology changes 212 last change occurred 07:37:33 ago from GigabitEthernet0/33
My switch port:
interface GigabitEthernet0/33
switchport access vlan 18
switchport mode access
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
queue-set 2
mls qos trust cos
no snmp trap link-status
auto qos voip trust
Is that a normal behavior? What can be a possible issue?
Thank you
8 Replies 8
cadet alain
you're correct a Portfast port will not send any TCN but did you verify you port is indeed in Portfast mode ?
Show spanning-tree interface g0/33 will tell you so.
Regards.
Alain
Here bellow:
#sh spanning-tree interface gigabitEthernet 0/33
Vlan             Role Sts Cost      Prio.Nbr Type
VLAN0060         Desg FWD 4         128.34   Edge P2p
#sh run interface gigabitEthernet 0/33
queue-set 2
mls qos trust cos
auto qos voip trust
the correct syntax was sh spanning-tree interface g0/33 portfast.
Sorry for the error.
Regards.
Alain
it's enabled
#sh spanning-tree interface gigabitEthernet 0/33 portfast
VLAN0060         enabled
Hi tdrumond,
are you running Rapid PVST ??
which swiitch ??
may be its a bug :
I has been detected on Cat3550 as CSCeb48939 .
Please rate if it helps.
Hi sandeepchoudhary21
I'm using a 3560:
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
and
spanning-tree mode pvst
Hi there,
disable the DTP with switchport none and let me know pls. Hardcode the speed and the duplex mode too.
Take Care
Alessio
Ok, now it's off, but I need some time to get results
