total number of Policy-map
yasserTL
Hello
I currently have the NCS 540 device, which has several policy-maps on its interfaces. I was wondering if there is a command that can show me the total number of policy-maps used in the device. Is that possible?
M02@rt37
Hello @yasserTL,
there isn't a direct command on Cisco devices to display the total number of policy-maps configured on the device in a single command. However, you can use the show policy-map interface command to view policy-maps configured on specific interfaces. To get an overview of all policy-maps configured on the device, you can use the show running-config | include policy-map command to display all lines in the running configuration that contain the keyword "policy-map."
Best regards
M02@rt37
Hello @yasserTL,
Best regards
show policy-map interface x/x <<- try this
Thanks A Lot
MHM
did you try this command ?
Thanks A Lot
MHM
