Total Output Drops on Interface on a Cat-6506
its-neteng
I have 2 Cat-6506's that are used for my WiSM's.  The only thing in both Chassis is 2 X WiSMs a SUP-7203A and a 6516A line card.
The only connection between the rest of the network and these chassis is on port gig 1/2.
This is the sh int gig 1/2 for that interface:
CISCO-6506#sh int gig 1/2
GigabitEthernet1/2 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 000d.28cb.3bd9 (bia 000d.28cb.3bd9)
  Description: (s-12508 Bldg 15)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 109/255, rxload 41/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is SX
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input 00:00:01, output never, output hang never
  Last clearing of "show interface" counters 00:53:34
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 7929413
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 161934000 bits/sec, 23151 packets/sec
  5 minute output rate 430715000 bits/sec, 168460 packets/sec
     59135665 packets input, 45168219877 bytes, 0 no buffer
     Received 2264364 broadcasts (1403835 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     567906655 packets output, 178163339303 bytes, 0 underruns
Notice that I cleared the Interface Counters 53Min ago and the Total Output drops is already at 7,929,413 and climbing.
This is the result from the show counters int gig 1/2
CISCO-6506#sh counters interface gigabitEthernet 1/2
64 bit counters:
0.                      rxHCTotalPkts = 173455982356
1.                      txHCTotalPkts = 444977190219
2.                    rxHCUnicastPkts = 152034993681
3.                    txHCUnicastPkts = 443597525143
4.                  rxHCMulticastPkts = 11873776884
5.                  txHCMulticastPkts = 1009753570
6.                  rxHCBroadcastPkts = 1708050100
7.                  txHCBroadcastPkts = 369911506
8.                         rxHCOctets = 158955667705181
9.                         txHCOctets = 167838361622740
10.                 rxTxHCPkts64Octets = 20028855128
11.            rxTxHCPkts65to127Octets = 68365953169
12.           rxTxHCPkts128to255Octets = 263550226871
13.           rxTxHCPkts256to511Octets = 70737965303
14.          rxTxHCpkts512to1023Octets = 47682184205
15.         rxTxHCpkts1024to1518Octets = 95857455440
16.                    txHCTrunkFrames = 444976348820
17.                    rxHCTrunkFrames = 169897598943
18.                     rxHCDropEvents = 0
32 bit counters:
0.                   rxCRCAlignErrors = 0
1.                   rxUndersizedPkts = 0
2.                    rxOversizedPkts = 0
3.                     rxFragmentPkts = 0
4.                          rxJabbers = 0
5.                       txCollisions = 0
6.                         ifInErrors = 0
7.                        ifOutErrors = 0
8.                       ifInDiscards = 10
9.                  ifInUnknownProtos = 0
10.                      ifOutDiscards = 888273867
11.            txDelayExceededDiscards = 0
12.                              txCRC = 0
13.                         linkChange = 16
14.                   wrongEncapFrames = 0
All Port Counters
1.                          InPackets = 173455967429
2.                           InOctets = 158955658166195
3.                        InUcastPkts = 152034981265
4.                        InMcastPkts = 11873776524
5.                        InBcastPkts = 1708049887
6.                         OutPackets = 444977049739
7.                          OutOctets = 167838314357672
8.                       OutUcastPkts = 443597384953
9.                       OutMcastPkts = 1009753394
10.                       OutBcastPkts = 369911392
11.                           AlignErr = 0
12.                             FCSErr = 0
13.                            XmitErr = 0
14.                             RcvErr = 0
15.                          UnderSize = 0
16.                          SingleCol = 0
17.                           MultiCol = 0
18.                            LateCol = 0
19.                       ExcessiveCol = 0
20.                       CarrierSense = 0
21.                              Runts = 0
22.                             Giants = 0
23.                         InDiscards = 10
24.                        OutDiscards = 888272926
25.                           InErrors = 0
26.                          OutErrors = 0
27.                    InUnknownProtos = 0
28.                              txCRC = 0
29.                      TrunkFramesTx = 444976208340
30.                      TrunkFramesRx = 169897584039
31.                         WrongEncap = 0
32.     Broadcast_suppression_discards = 0
33.     Multicast_suppression_discards = 0
34.       Unicast_suppression_discards = 0
35.                 rxTxHCPkts64Octets = 20028852866
36.            rxTxHCPkts65to127Octets = 68365944266
37.           rxTxHCPkts128to255Octets = 263550137767
38.           rxTxHCPkts256to511Octets = 70737943115
39.          rxTxHCpkts512to1023Octets = 47682164190
40.         rxTxHCpkts1024to1518Octets = 95857443166
41.                         DropEvents = 0
42.                     CRCAlignErrors = 0
43.                     UndersizedPkts = 0
44.                      OversizedPkts = 0
45.                       FragmentPkts = 0
46.                            Jabbers = 0
47.                         Collisions = 0
48.              DelayExceededDiscards = 0
49.                        bpduOutlost = 0
50.                        qos0Outlost = 0
51.                        qos1Outlost = 0
52.                        qos2Outlost = 0
53.                        qos3Outlost = 888272926
54.                        qos4Outlost = 0
55.                        qos5Outlost = 0
56.                        qos6Outlost = 0
57.                        qos7Outlost = 0
58.                        qos8Outlost = 0
59.                        qos9Outlost = 0
60.                       qos10Outlost = 0
61.                       qos11Outlost = 0
62.                       qos12Outlost = 0
63.                       qos13Outlost = 0
64.                       qos14Outlost = 0
65.                       qos15Outlost = 0
66.                       qos16Outlost = 0
67.                       qos17Outlost = 0
68.                       qos18Outlost = 0
69.                       qos19Outlost = 0
70.                       qos20Outlost = 0
71.                       qos21Outlost = 0
72.                       qos22Outlost = 0
73.                       qos23Outlost = 0
74.                       qos24Outlost = 0
75.                       qos25Outlost = 0
76.                       qos26Outlost = 0
77.                       qos27Outlost = 0
78.                       qos28Outlost = 0
79.                       qos29Outlost = 0
80.                       qos30Outlost = 0
81.                       qos31Outlost = 0
82.                    bpduCbicOutlost = 0
83.                    qos0CbicOutlost = 0
84.                    qos1CbicOutlost = 0
85.                    qos2CbicOutlost = 0
86.                    qos3CbicOutlost = 0
87.                         bpduInlost = 0
88.                         qos0Inlost = 0
89.                         qos1Inlost = 0
90.                         qos2Inlost = 0
91.                         qos3Inlost = 10
92.                         qos4Inlost = 0
93.                         qos5Inlost = 0
94.                         qos6Inlost = 0
95.                         qos7Inlost = 0
96.                         qos8Inlost = 0
97.                         qos9Inlost = 0
98.                        qos10Inlost = 0
99.                        qos11Inlost = 0
100.                        qos12Inlost = 0
101.                        qos13Inlost = 0
102.                        qos14Inlost = 0
103.                        qos15Inlost = 0
104.                        qos16Inlost = 0
105.                        qos17Inlost = 0
106.                        qos18Inlost = 0
107.                        qos19Inlost = 0
108.                        qos20Inlost = 0
109.                        qos21Inlost = 0
110.                        qos22Inlost = 0
111.                        qos23Inlost = 0
112.                        qos24Inlost = 0
113.                        qos25Inlost = 0
114.                        qos26Inlost = 0
115.                        qos27Inlost = 0
116.                        qos28Inlost = 0
117.                        qos29Inlost = 0
118.                        qos30Inlost = 0
119.                        qos31Inlost = 0
120.                         pqueInlost = 0
121.                           Overruns = 10
122.                           maxIndex = 0
Notice the qos3outlost counters.
So the questions is what can I do to resolve this issue?  If I have read other posts correctly all points to the ASIC being overun by that traffic being sent from my WiSMs out to the Network.
Can you run and post a "show interface gig 1/2 capabilities" on the 6500 end and run the same command for the respective interface on the directly connected device? The QoS scheduling settings must be the same on both devices.
Also what is your gig1/2 on? the 6516 LC?
************** Tristan Manduley Cisco TAC
