Total Output Drops WS-C3750E-48TD-E
I have a problem with Total Output Drops, it's increase and decreases on WS-C3750E-48TD-E.
SWCIACTCT05#sh int gi1/0/47 | i  Total output drops:
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 6487344
I checked and found two registered bug id: CSCtq86186 / CSCso81660.
I would like to know what is the best IOS version to update my switch, IOS 15.0.2 SE2 or 12.2.58 SE2, by the way, my environment is very critical (data center) and the version 15.0.2 SE2 is very recent, but its stable ?
In both versions the problem are fixed?
Thanks.
Leo Laohoo
Unless you critically need features found in these two versions, try 12.2(55)SE6 or SE7.
Sent from Cisco Technical Support Nintendo App
Leo Laohoo
Leolaohoo,
What you can talk to me about this versions, 12.2(55) SE6 and SE7 ?
This is a stable version? without many bugs?
Thnks.
This version is more stable than the higher versions.
Just started testing 15.0(2)SE2 a few days ago so I can't don't have anything to report.
