Traceback switch 3750
Ronald Garcia
Hello my friends,
I want some opinions of these traceback:
Jul 31 11:45:15:  invalid mask index 0x4CCCCF59, context = 16BA0E8/144bit-context,
             first_mask_index = 0x0, last_mask_index = 0x4AF
Jul 31 11:45:15: -Traceback= 3182F4 31C264 31C9E8 31CB88 31CD94 378FCC 37AC28 37A97C 36E860 36F780 36315C 363A4C 75E3A8 7585EC
Jul 31 11:45:15: %TCAMMGR-3-INDEX_ERROR: cam value/mask index 1288490841 is invalid
-Traceback= 97CFEC 318318 31C264 31C9E8 31CB88 31CD94 378FCC 37AC28 37A97C 36E860 36F780 36315C 363A4C 75E3A8 7585EC
Jul 31 11:45:19:  invalid mask index 0x4CCCCF59, context = 16BA0E8/144bit-context,
Jul 31 11:45:19: -Traceback= 3182F4 31C264 31C9E8 31CB88 31CD94 378FCC 37AC28 37A97C 36E860 36F780 36315C 363A4C 75E3A8 7585EC
Jul 31 11:45:19: %TCAMMGR-3-INDEX_ERROR: cam value/mask index 1288490841 is invalid
Jul 31 11:45:21: %STORM_CONTROL-3-FILTERED: A Broadcast storm detected on Fa1/0/22. A packet filter action has been applied on the interface.
Jul 31 11:45:24:  invalid mask index 0x4CCCCF59, context = 16BA0E8/144bit-context,
Jul 31 11:45:24: -Traceback= 3182F4 31C264 31C9E8 31CB88 31CD94 378FCC 37AC28 37A97C 36E860 36F780 36315C 363A4C 75E3A8 7585EC
Jul 31 11:45:24: %TCAMMGR-3-INDEX_ERROR: cam value/mask index 1288490841 is invalid
Jul 31 11:45:28:  invalid mask index 0x4CCCCF59, context = 16BA0E8/144bit-context,
Jul 31 11:45:28: -Traceback= 3182F4 31C264 31C9E8 31CB88 31CD94 378FCC 37AC28 37A97C 36E860 36F780 36315C 363A4C 75E3A8 7585EC
Jul 31 11:45:28: %TCAMMGR-3-INDEX_ERROR: cam value/mask index 1288490841 is invalid
Jul 31 11:45:32:  invalid mask index 0x4CCCCF59, context = 16BA0E8/144bit-context,
Jul 31 11:45:32: -Traceback= 3182F4 31C264 31C9E8 31CB88 31CD94 378FCC 37AC28 37A97C 36E860 36F780 36315C 363A4C 75E3A8 7585EC
Jul 31 11:45:32: %TCAMMGR-3-INDEX_ERROR: cam value/mask index 1288490841 is invalid
Jul 31 11:45:37:  invalid mask index 0x4CCCCF59, context = 16BA0E8/144bit-context,
Jul 31 11:45:37: -Traceback= 3182F4 31C264 31C9E8 31CB88 31CD94 378FCC 37AC28 37A97C 36E860 36F780 36315C 363A4C 75E3A8 7585EC
Jul 31 11:45:37: %TCAMMGR-3-INDEX_ERROR: cam value/mask index 1288490841 is invalid
Jul 31 11:45:41:  invalid mask index 0x4CCCCF59, context = 16BA0E8/144bit-context,
Jul 31 11:45:41: -Traceback= 3182F4 31C264 31C9E8 31CB88 31CD94 378FCC 37AC28 37A97C 36E860 36F780 36315C 363A4C 75E3A8 7585EC
Jul 31 11:45:41: %TCAMMGR-3-INDEX_ERROR: cam value/mask index 1288490841 is invalid
Jul 31 11:45:45:  invalid mask index 0x4CCCCF59, context = 16BA0E8/144bit-context,
Jul 31 11:45:45: -Traceback= 3182F4 31C264 31C9E8 31CB88 31CD94 378FCC 37AC28 37A97C 36E860 36F780 36315C 363A4C 75E3A8 7585EC
Jul 31 11:45:45: %TCAMMGR-3-INDEX_ERROR: cam value/mask index 1288490841 is invalid
Thanks a lot my friend
kapathak
Hello Ronald,
This most likely is a hardware problem and you should look to replace the switch reporting the error. The tracebacks do not seem to point towards any known bugs and all similar symptoms reported in the past by various users/customers seem to have been resolved by switch replacement.
Kapil
6 Replies 6
Ronald Garcia
is there relation between:
y
thanks
Please tell which IOS version you are using.
Sweta
sweta:
C3750 Software (C3750-ADVIPSERVICESK9-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1)
thanks
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
"C3750 Software (C3750-ADVIPSERVICESK9-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1)"
"I want some opinions of these traceback:"
Try later code.
kapathak
Hello Ronald,
Kapil
Leo Laohoo
I agree with Joseph.  Your IOS is pretty old (I haven't seen this version since 2006).   It's about time you upgrade your IOS to a new level.  Take note that you have a 3750 so the highest your stack can go is 12.2(55)SE and later.
