traceroute and VLANs
fzaynoun
my settings:
Switch layer 3 SF300-24 set in layer 3 mode. i setup 3 vlans, in addition to the default vlan1. all routing work fine between the different vlans. My problem is that in traceroute (say if i traceroute from a pc connected to a vlan), the vlan ips will appear as * * *, not detectable. how to make them respond to traceroute or make vlans traceroute visible ?
Hello
Can you please post your config
Res
paul
Kind Regards
Paul
switch1#sh run
config-file-header
switch1
v1.2.9.44 / R750_NIK_1_2_584_002
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 2-4
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp relay address 10.10.4.2
ip dhcp relay enable
ip dhcp information option
bonjour interface range vlan 1
hostname switch1
no passwords complexity enable
username cisco password encrypted f84f7bb9b5e52e3b755d7ec0496c50e8404869d8 privi
lege 15
ip telnet server
interface vlan 1
ip address 192.168.1.254 255.255.255.0
no ip address dhcp
interface vlan 2
name "x"
ip address 10.10.2.1 255.255.255.0
interface vlan 3
name "y"
ip address 10.10.3.1 255.255.255.0
interface vlan 4
name Server
ip address 10.10.4.1 255.255.255.0
interface fastethernet1
switchport mode access
switchport access vlan 2
interface fastethernet2
interface fastethernet3
interface fastethernet4
switchport access vlan 3
interface fastethernet5
interface fastethernet6
interface fastethernet7
switchport access vlan 4
interface fastethernet8
ip route 0.0.0.0 0.0.0.0 192.168.1.1
switch1#
Disable Firewall on PC and PC gateway Must be Vlan IP.
Jawad
