track and sla reachbility
sarahr202
Level 5
Level 5
Hi everybody
Please consider the following
R1(config)track 2 ip sla 11 state.
When the above command is configured, the "tracking object 2"   will look at ip sla operation's recent return code then determine the tracking state as either up or down.
What will happen If i configure:
R1(config)# track 2 ip sla 11 reachability
In short when we use the option " reachbility"  as in above command. what will tracking object 2 do ?
Thanks and have a great day
Amit Singh
Hi Sarah,
State tracks the error return code for the tracked IP SLA object.
Reachability tracks if the route is reachable or not.
You would use reachability code if you are trying to track a static route.
Cheers,
-amit singh
Amit Singh
Hi Sarah,
Cheers,
-amit singh
