TRACKING CONNECTED DEVICE DOWN A CISCO SWITCH
chrismtove
I have IP address and mac address i wanted to track down on which exactly switch and ports it the device connected also is cisco device but when i run the below commands does not show any output what could be the problems?
TAASERVER3750-1#show mac address-table address 544a.00bc.9f40
Mac Address Table
Vlan Mac Address Type Ports
TAASERVER3750-1#show mac address-table | include 544a.00bc.9f40
TAASERVER3750-1#
How can i locate the switch and ports please?
Mark Malone
Ping the ip address again so it goes into the mac/arp tables then use your commands above to trace
You can only trace macs that are live in the layer 2 tables
ok
i will try later but if you show ip arp
TAASERVER3750-1#show ip arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 192.168.1.98 68 90b1.1ca7.acda ARPA Vlan1
Internet 192.168.1.65 0 34e6.d70c.57d1 ARPA Vlan1
Internet 192.168.1.66 224 544a.00bc.9f40 ARPA Vlan1
Internet 192.168.1.13 0 001b.7896.6cb4 ARPA Vlan1
Internet 192.168.1.24 92 001d.e69c.dac0 ARPA Vlan1
Internet 192.168.1.20 37 0090.fb4a.99e8 ARPA Vlan1
Internet 192.168.1.23 1 001d.e6d2.ec40 ARPA Vlan1
Internet 192.168.1.22 - 001d.e629.82c0 ARPA Vlan1
Internet 192.168.1.242 128 0021.9b37.adf9 ARPA Vlan1
Internet 192.168.1.216 229 bc30.5bab.5159 ARPA Vlan1
Internet 192.168.1.161 238 782b.cbae.00ca ARPA Vlan1
Internet 192.168.1.166 192 0023.ae90.3f7e ARPA Vlan1
now i wanted to get exactly the port connected with the ip .66 and its mac address as show above in bolded
you should be able to once its in your arp table and complete that's exactly how you trace a layer 2 mac as below
SW1#sh mac address-table address d89d.6714.03ac
          Mac Address Table
   1    d89d.6714.xxxx    DYNAMIC     Gi0/44
Total Mac Addresses for this criterion: 1
sw1#sh ip arp d89d.6714.xxxx
Internet  189.x.x.x       189   d89d.6714.xxxx  ARPA   Vlan1
