Traffic engineering
ror.sanjeev
Community Member
Hi.I have following questuon.
the subnet to which host belongs, connected to a 7507 router and host at other end belongs to other subnet which is connected to 2811 Cisco router's interface.There is 2Mbps point-to-point connection between two routers.I would like to segment the 2Mbps bandwidth so that particular host in both subnets should get the more bandwidth than others.Say the following topology:
Subnet: 192.168.1.0/24,host 192.168.1.2,gateway(router) 192.168.0.1 <<-----2Mbps Connection--->>Subnet 192.168.2.0/24,host 192.168.2.2,gateway(router):192.168.2.1, there are also other hosts in both subnets.I want to segment the bandwidth so that host 192.168.1.2 and 192.168.2.2 should get at least 128Kbps bandwidth , and others will get the remaining bandwidth..Is it possible to do , if yest then on which network device, either on router at both ends or hosts ate both end ???
-Sanjeev
Network and Security Admin
Giuseppe Larosa
Hello Sanjeev,
you can use QoS on both routers.
access-list 101 permit ip host 192.168.1.2 host 192.168.2.2
class-map selectedflow
match access-group 101
policy-map myscheduler
class selectedflow
bandwidth 128
class class-default
fair-queue
int serx/y
service-policy out myscheduler
on the other end you need a different ACL with hosts in reverted order.
access-list 102 permit ip host 192.168.2.2 host 192.168.1.2
all the rest is the same but needs to be configured on both routers.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Sanjeev,
class selectedflow
bandwidth 128
class class-default
fair-queue
int serx/y
Hope to help
Giuseppe
Hi.thank you very much for the reply.
What I understand it will restrict bandwidth for both end-hosts.But I want at least 128Kbps or more from 2Mbps for both end hosts,or if available they can get more than 128Kbps, because that is also used by other hosts in subnets,If less users are using it and 2Mbps bandwidth is free then they can use more than 128Kbps.But they should get at least 128Kbps.And that 128Kbps bandwidth dedicated to end hosts will not be disturbed by other hosts.I hope you are getting my question.
thanks again,waiting for reply.
Hello Sanjeev,
bandiwidth command in CBWFQ provides the mininum bw for the class when the link is full.
but the mechanism is elastic and does not include a rate limiting action: if there are free resources on link the class can use more then 128 kbps.
so it should fit your needs
Hope to help
Giuseppe
