traffic error
fawzi Abdullah
Community Member
Hello Every one..
Good Morning ..
i have four switches CBS350-48P-4G 48-Port Gigabit PoE Managed Switch and i facing an issue ( traffic error  code: undersize packets ,CRC& Align Error, internal MAC receive Error)  so i need to your support to fix these issues
Regard.
Hello
check your cabling
port speed/duplex settings
Kind Regards
Paul
Hello Paul,
Thank you for support.
This issue as well with interface port that not up as well ,that mean the cable has nothing to do with the issue
The port speed/duplex setting is good , find attached , this one sample for one port ,
