Traffic in same VLAN goes up trunk
Andy White
Level 3
Level 3
I have 2 hosts, 1 plugged in fa 0/21 in VLAN 101 and another in fa 0/22 in VLAN 101 on our L2 Cisco 2960.  If I try and transfer files from either host the gig 0/1 trunk port on the 2960 leading tot he 3750 fa 0/1 port hits 100mb (using a real time bandwidth monitor tool), but why?  This VLAN is on the same switch, why does it go one way up the trunk to the L3 3750 switch?  The L3 3750 is the VTP server and the 2960 is a client.  I would of thought the traffic stays local.  The 2 hosts don't even have a gateway set.
To sum up the typology the 2960 and 3750 are trunked using a single cable.  The 3750 hangs of a ASA firewall using SVIs.
Here is whatthe traffic looks like when copying a file between hosts (2gb file).
3750 L3 Switch (VTP Server)
interface FastEthernet1/0/4
description Trunk to Cisco 2960 Gig 0/1
switchport mode trunk
switchport nonegotiate
2960 L2 Switch (VTP Client)
interface FastEthernet0/21
description test
switchport access vlan 101
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
interface FastEthernet0/22
description test
interface GigabitEthernet0/1
description Trunk to 3750 1/0/4
interface GigabitEthernet0/2
shutdown
interface Vlan1
no ip address
interface Vlan12
ip address 10.1.2.254 255.255.255.0
no ip route-cache
Port        Mode             Encapsulation  Status        Native vlan
Gi0/1       on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi0/1       1-4094
Port        Vlans allowed and active in management domain
Gi0/1       1-6,9-15,100-101,123,300
Port        Vlans in spanning tree forwarding state and not pruned
Gi0/1       1-6,9-15,100,123,300
Drac-Switch#
Any ideas?
6 Replies 6
cadet alain
vlan 101  is not there:
so there should be no vlan 101 traffic going through this trunk.
Alain
So is it pruned?
A "sh vlan bri" shows it there though, I had to create the VLAN on the VTP server then I coudl see it onthe client and then assigned the ports to VLAN 101:
sh vlan bri
VLAN Name                             Status    Ports
1    default                          active    Fa0/13, Fa0/16, Fa0/23, Fa0/24, Gi0/2
2    ****                           active
3    ****                          active
4    ****                          active
5    ****                          active
6    ****                         active
9    ****                          active
10   ****                         active
11   ****                        active
12   ****                       active    Fa0/1, Fa0/2, Fa0/7, Fa0/8, Fa0/9, Fa0/10, Fa0/11, Fa0/12, Fa0/14, Fa0/15
13   ****                       active
14   ****                       active
15   ****                        active
100  ****                        active    Fa0/17, Fa0/18, Fa0/19, Fa0/20
101  Test_VLAN                 active    Fa0/3, Fa0/4, Fa0/5, Fa0/6, Fa0/21, Fa0/22
123  ****                           active
300  ****                             active
1002 fddi-default                     act/unsup
1003 trcrf-default                    act/unsup
1004 fddinet-default                  act/unsup
1005 trbrf-default                    act/unsup
Drac-Switch#
it is pruned or the STP is not forwarding this vlan on this interface, so i wonder how you get traffic.
could you do a span session to see which traffic is passing through this trunk when you transfer your files ?
Alain
I found out what it was.  The switch had RSPAN running and was sending the VLAN traffic up the trunk to the remote network analyzer - doh.  Silly me.
Thanks for your time though.
Hello Andy,
you have been kind to provide feedback on this issue.
You don't need to apologize.
Best Regards
Giuseppe
Thanks, what I love about finding issues like this is a resolution, even if it was something simple or silly as for me it is the best way to learn.  Once I found it out what it was it all made sense as to why the traffic was only going up the trunk and never down
