Traffic rate on interfaces
nedk12345
Hi, what is theoretical limit on an interface vs the actual practical limit. For eg. if the actual link is a 100Mb Internet Circuit but the physical interface is a Gigabit interface on switch configured with speed 100 than is it possible to go above the 100Mb. I have always been under assumption the speed setting on the interface controls the actual theoretical traffic limit as well as the practical maximum. If there is more traffic than 100Mb (the speed of interface) than it will be buffered and than dropped if there are no buffers but it will never send out more than the configured speed setting. Is this correct. Thanks
Joseph W. Doherty
If we're discussing Ethernet, a multiple speed interface only runs as one speed. So, for a 10/100/1000 interface connected to, on the other side of the link, a 10/100 interface, your actual speed would be either 10 or 100.
For Ethernet, the speed could be fixed for the port (i.e. there are 10, 100 and gig only ports), auto configured (on multi speed capable interfaces),or manually configured (on multi speed capable interfaces), e.g. "speed 100".
When working with WAN Ethernet hand-offs, such as perhaps your 100 Mbps Interlink, it's quite common for the WAN to physically send/receive at physical bandwidth but measure actual bandwidth utilization. Bandwidth utilization beyond the agreed usage might be dropped or shaped. I.e. a 100 Mbps hand-off might only offer "25" Mbps.
This is a different from some serial interfaces that either use channels of blocks of bandwidth (e.g. DS0 channels of a DS1) or physically "clock" a certain bandwidth rate.
Neither of these bandwidths should be confused with the bandwidth statement offen seen on interfaces, which provides a logical bandwidth to other device functions.
PS:
Oh and yes, you can't send/receive faster than the phyical bandwidth provided.
If you actually configured both sides of an Ethernet interface at different physical speeds, e.g. one side 100, other gig, they would be unable to communicate at all (I believe).
Joseph W. Doherty
PS:
hi ould it be possible to send more than 100Mb if both sides interface are configured at 100Mb but the physical circuit is 1000Mb
Depends on what you mean by "both sides interface are configured at 100Mb but the physical circuit is 1000Mb".
If for example, 3x speed Ethernet interface using gig capable copper, but interfaces configured as "speed 100", the anwer is no. If interface configured "speed auto" or "speed 1000" then yes, unless there's also a policer or shaper configured for 100 Mbps.
hello
given scenario below
user port interface on switch is manually set for 100m but physically it can go to 1000m
user machine nic manually set for 100m but physically it can go to 1000m
can user machine send more than 100m. if no than why. port is capable on both sides what is stopping electrically from sending more than 100. what would happen to trafffic above 100m if there is no qos just normal port.
thanks
