Traffice Not Routing
TXITGUY9000
I have a C3850 and I am trying to route network 192.168.98.0 to the next hop of 192.168.98.2. I can ping across and back with no issues. Any suggestions?
ip routing
ip route 0.0.0.0 0.0.0.0 192.168.10.1
ip route 192.168.98.0 255.255.255.0 192.168.98.2
Gateway of last resort is 192.168.10.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 192.168.10.1
      192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.10.0/24 is directly connected, Vlan10
L        192.168.10.2/32 is directly connected, Vlan10
      192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.20.0/24 is directly connected, Vlan20
L        192.168.20.1/32 is directly connected, Vlan20
      192.168.30.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.30.0/24 is directly connected, Vlan30
L        192.168.30.1/32 is directly connected, Vlan30
      192.168.40.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.40.0/24 is directly connected, Vlan40
L        192.168.40.1/32 is directly connected, Vlan40
      192.168.98.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.98.0/24 is directly connected, Vlan98
L        192.168.98.1/32 is directly connected, Vlan98
      192.168.99.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.99.0/24 is directly connected, Vlan1
L        192.168.99.1/32 is directly connected, Vlan1
      192.168.100.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.100.0/24 is directly connected, Vlan100
L        192.168.100.1/32 is directly connected, Vlan100
Hello
@TXITGUY9000 wrote:
Thanks for the response. Yes it is routing currently to 192.168.10.1, but I want to force traffic on the 98 network to route to 192.168.98.2 and all other traffic to the 192.168.10.1
access-list 10 permit 192.168.98.0 0.0.0.255
route-map PBR
match ip address 10
set ip next-hop 192.168.10.1
int vlan 98
ip polcy route-map PBR
Kind Regards
Paul
Muhammad Awais Khan
i can see 192.168.98.1 is already configured as SVI in your VLAN 98 interface so it is already appearing as connected subnet in your Routing table:
There is no need to add below static Route. Even if you add it, it will not appear as static route as it is already a connected subnet
 If your VLAN98 interface is up, you will be able to reach any  IP in 92.168.98.0/24 network
Any idea what I am doing wrong?
what source IP addresses do you want to route ? Probably the only way to (maybe) do this is to use policy based routing, and the 'set ip next-hop' command (which causes the system to first use policy routing and then use the routing table).
Post the full configuration of your 3850 and indicate which source networks you want to be routed towards that next hop (192.168.98.2).
Hello
route-map PBR
match ip address 10
int vlan 98
Kind Regards
Paul
