Training
rjafri7860
I have basic knowledge of Switching/Routing. I am looking for Advanced technical training from Cisco.
What is recommended training from Cisco.
Edison Ortiz
Most of the knowledge in Switching and Routing comes from hands-on experience. If you feel you are weak in a particular area, you should investigate nearby training providers and check their course catalog.
All courses are targeted to a specific area of networking.
HTH,
__
Edison.
Istvan_Rabai
Level 7
Level 7
Hi Rahat,
Here's a link that you can use to decide which direction to take and what could be your next step for training.
http://www.cisco.com/web/learning/le3/learning_career_certifications_and_learning_paths_home.html
Also, you can find some trainig literature at www.ciscopress.com
Cheers:
Istvan
johnmkaranja021
I would recommend you browse through Learncisco.net and see if that is what you want.
John
Bigoncisco
Hi try this blog. It good recommendations.
