Transmit discards issue
lmanavalan
Level 3
Level 3
Our monitoring tool (solar wind) is showing Transmit discards on the interface between border router ( ASR1004) and core switch (WS-C6509-E).
But i don't see the error when i check the router or switch.
NODE    INTERFACE        Rx_ERRORS    Rx_DISCARDS    Tx_ERRORS    Tx_DISCARDS
Router    Te0/0/0 to Sw      0 error                 0 discards              0 error                28,757,546 discards
Logesh
Leo Laohoo
Post the output to the router command "sh interface Ten 0/0/0".
Want to mention that we have configured few sub-interfaces too.
border router#sh interface Ten 0/0/0
TenGigabitEthernet0/0/0 is up, line protocol is up
  Hardware is SPA-1X10GE-L-V2, address is bc17.6579.e277 (bia bc17.6579.e277)
  Description: *te0/0/0* - *to coreswitch,te3/3*
  MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 20/255, rxload 20/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive not supported
  Full Duplex, 10000Mbps, link type is force-up, media type is 10GBase-SR/SW
  output flow-control is on, input flow-control is on
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/375/1238/1719 (size/max/drops/flushes); Total output drops: 2673209411
  Queueing strategy: Class-based queueing
  Output queue: 0/40 (size/max)
  30 second input rate 811050000 bits/sec, 197425 packets/sec
  30 second output rate 808476000 bits/sec, 197267 packets/sec
     5216106870671 packets input, 2735320776306911 bytes, 0 no buffer
     Received 542360263 broadcasts (0 IP multicasts)
     0 watchdog, 1147197616 multicast, 0 pause input
     5211621651445 packets output, 2726859315982820 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
