trouble communicating accross trunk
mikeharrold
i have posted the configs from both switches. one switch is a 6503 the other is a 3750.  both switchs are layer 3.  i am unable to ping between them on vlan 254.  i can ping the directly connected vlan just not the vlans accross the trunk. any help would be appreciated.
thank you
config for 6503
version 12.2
hostname CR1-SW6503-1
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
spanning-tree backbonefast
--More--                           spanning-tree vlan 1 priority 0
spanning-tree vlan 10,20,22,30,110,120,130 priority 8192
spanning-tree vlan 11,21,71,111,121 priority 4096
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
redundancy
mode sso
main-cpu
  auto-sync running-config
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
interface Port-channel1
no ip address
switchport
switchport trunk allowed vlan 1,2,10,11,20-22,30,110,111,120,121,130
switchport mode trunk
interface GigabitEthernet1/1
no ip address
switchport
switchport access vlan 70
interface GigabitEthernet1/2
no ip address
switchport
interface GigabitEthernet3/1
no ip address
switchport
switchport trunk allowed vlan 1,2,10,11,20-22,30,110,111,120-122,130,252-254
interface GigabitEthernet3/3
no ip address
switchport
switchport trunk allowed vlan 1,2,20-22,120-122
interface GigabitEthernet3/4
no ip address
switchport
switchport trunk allowed vlan 1,2,10,11,30,99,110,111,120,130
interface GigabitEthernet3/5
no ip address
switchport
switchport trunk allowed vlan 1,30,130
interface GigabitEthernet3/23
no ip address
switchport
interface GigabitEthernet3/24
no ip address
load-interval 30
switchport
switchport trunk allowed vlan 1,70,71,99,252-254
interface Vlan1
ip address 10.2.200.253 255.255.0.0
ip policy route-map TO_ASA
standby 1 ip 10.2.200.254
standby 1 priority 110
standby 1 preempt
interface Vlan2
ip address 10.3.1.11 255.255.255.0
interface Vlan10
ip address 10.3.10.2 255.255.255.0
ip helper-address 10.2.200.92
ip policy route-map ASA
standby 10 ip 10.3.10.1
standby 10 priority 200
standby 10 preempt
interface Vlan11
description North  Data
ip address 10.3.11.2 255.255.255.0
standby 11 ip 10.3.11.1
standby 11 priority 210
standby 11 preempt
interface Vlan20
description  Data
ip address 10.3.20.2 255.255.255.0
standby 20 ip 10.3.20.1
standby 20 priority 200
standby 20 preempt
interface Vlan21
description  Data
ip address 10.3.21.2 255.255.255.0
--More--                            ip policy route-map ASA
standby 21 ip 10.3.21.1
standby 21 priority 210
standby 21 preempt
interface Vlan22
description Data Center - Data
ip address 10.3.22.2 255.255.255.0
standby 22 ip 10.3.22.1
standby 22 priority 200
standby 22 preempt
interface Vlan30
description Training Center - Data
ip address 10.3.30.2 255.255.255.0
standby 30 ip 10.3.30.1
standby 30 priority 200
standby 30 preempt
interface Vlan71
description DR Location VLAN
ip address 10.71.0.252 255.255.0.0
interface Vlan99
description CR4 - Internet
ip address 10.3.99.2 255.255.255.0
interface Vlan110
description South - Voice
ip address 10.3.110.2 255.255.255.0
ip helper-address 10.3.122.10
standby 110 ip 10.3.110.1
standby 110 priority 110
standby 110 preempt
interface Vlan111
description North - Voice
ip address 10.3.111.2 255.255.255.0
standby 111 ip 10.3.111.1
standby 111 priority 210
standby 111 preempt
interface Vlan120
description  Voice
ip address 10.3.120.2 255.255.255.0
--More--                            standby 120 ip 10.3.120.1
standby 120 priority 200
standby 120 preempt
interface Vlan121
description  Voice
ip address 10.3.121.2 255.255.255.0
standby 121 ip 10.3.121.1
standby 121 priority 210
standby 121 preempt
interface Vlan122
description  - Voice
ip address 10.3.122.2 255.255.255.0
standby 122 ip 10.3.122.1
standby 122 priority 200
standby 122 preempt
interface Vlan130
description  Voice
ip address 10.3.130.2 255.255.255.0
standby 130 ip 10.3.130.1
standby 130 priority 200
standby 130 preempt
interface Vlan252
no ip address
interface Vlan253
no ip address
interface Vlan254
ip address 10.3.254.21 255.255.255.0
router eigrp 1
network 10.2.0.0 0.0.255.255
network 10.3.0.0 0.0.255.255
network 10.70.0.0 0.0.255.255
network 10.71.0.0 0.0.255.255
network 10.99.99.0 0.0.0.3
no auto-summary
router rip
network 10.0.0.0
no auto-summary
ip classless
--More--                           ip route 0.0.0.0 0.0.0.0 10.2.0.247
ip route 10.4.0.0 255.255.0.0 10.2.0.247
ip route 10.5.0.0 255.255.0.0 10.2.0.247
ip route 10.6.0.0 255.255.0.0 10.2.0.247
ip route 10.7.0.0 255.255.0.0 10.2.0.247
ip route 10.8.0.0 255.255.0.0 10.2.0.247
ip route 10.9.0.0 255.255.0.0 10.2.0.247
ip route 10.12.0.0 255.255.0.0 10.2.0.247
ip route 10.13.0.0 255.255.0.0 10.2.0.247
ip route 10.14.0.0 255.255.0.0 10.2.0.247
ip route 10.15.0.0 255.255.0.0 10.2.0.247
ip route 10.16.0.0 255.255.0.0 10.2.0.247
ip route 10.17.0.0 255.255.0.0 10.2.0.247
ip route 10.19.0.0 255.255.0.0 10.2.0.247
ip route 10.21.0.0 255.255.0.0 10.2.0.247
ip route 10.22.0.0 255.255.0.0 10.2.0.247
ip route 10.23.0.0 255.255.0.0 10.2.0.247
ip route 10.24.0.0 255.255.0.0 10.2.0.247
ip route 10.29.0.0 255.255.0.0 10.2.0.247
ip route 10.31.0.0 255.255.0.0 10.2.0.247
ip route 10.33.0.0 255.255.0.0 10.2.0.247
ip route 10.41.0.0 255.255.0.0 10.2.0.247
ip route 10.42.0.0 255.255.0.0 10.2.0.247
ip route 10.43.0.0 255.255.0.0 10.2.0.247
ip route 10.44.0.0 255.255.0.0 10.2.0.247
ip route 10.51.0.0 255.255.0.0 10.2.0.247
ip route 10.133.0.0 255.255.0.0 10.2.0.229
ip route 10.135.0.0 255.255.0.0 10.2.0.229
ip route 10.149.0.0 255.255.0.0 10.2.0.229
ip route 10.150.14.0 255.255.255.0 10.2.0.229
ip route 10.150.16.0 255.255.254.0 10.2.0.229
ip route 10.150.18.0 255.255.255.0 10.2.0.229
ip route 10.150.19.0 255.255.255.0 10.2.0.229
ip route 192.168.5.0 255.255.255.0 10.2.0.229
ip route 192.168.13.0 255.255.255.0 10.2.0.229
ip route 192.168.15.0 255.255.255.0 10.2.0.229
ip route 192.168.17.0 255.255.255.0 10.2.0.229
ip route 192.168.19.0 255.255.255.0 10.2.0.229
ip route 192.168.20.0 255.255.255.0 10.2.0.229
ip route 192.168.27.0 255.255.255.0 10.2.0.229
ip route 192.168.95.117 255.255.255.255 10.2.0.229
ip route 192.168.95.118 255.255.255.255 10.2.0.229
no ip http server
ip access-list extended ASA_ACL
deny   tcp host 10.2.0.5 any eq smtp
--More--                            deny   tcp host 10.2.0.15 any eq smtp
deny   tcp host 10.2.0.17 any eq smtp
deny   tcp host 10.2.0.131 any eq smtp
deny   tcp host 10.2.0.5 any eq www
deny   tcp host 10.2.0.17 any eq www
permit ip 10.2.0.0 0.0.255.255 any
logging 10.2.0.55
access-list 115 permit ip 10.3.0.0 0.0.255.255 any
access-list 116 permit ip 10.3.0.0 0.0.255.255 10.1.0.0 0.0.0.255
route-map TO_ASA permit 10
match ip address TO_ASA_ACL
set ip default next-hop 10.2.0.229
route-map ASA permit 5
match ip address 116
set ip default next-hop 10.2.0.247
route-map ASA permit 10
match ip address 115
dial-peer cor custom
ntp clock-period 17180079
ntp source Vlan1
ntp update-calendar
ntp server 128.59.59.177
ntp server 17.254.0.26
ntp server 128.118.25.3
end
config for 3750
version 12.2
hostname CR3-SW3750-1
switch 1 provision ws-c3750-48p
switch 2 provision ws-c3750-48p
switch 3 provision ws-c3750-48p
switch 4 provision ws-c3750-48p
switch 5 provision ws-c3750-48p
switch 6 provision ws-c3750-48p
switch 7 provision ws-c3750-48p
switch 8 provision ws-c3750-48p
system mtu routing 1500
ip subnet-zero
ip routing
spanning-tree uplinkfast
interface GigabitEthernet1/0/1
description Uplink
switchport trunk allowed vlan 1,2,10,11,30,99,110,111,120,130,252-254
interface GigabitEthernet1/0/2
--More--                           !
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
i
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet3/0/1
interface GigabitEthernet3/0/2
interface GigabitEthernet3/0/3
interface GigabitEthernet3/0/4
interface GigabitEthernet4/0/1
interface GigabitEthernet4/0/2
interface GigabitEthernet4/0/3
interface GigabitEthernet4/0/4
interface GigabitEthernet5/0/1
interface GigabitEthernet5/0/2
interface GigabitEthernet5/0/3
interface GigabitEthernet5/0/4
interface GigabitEthernet6/0/1
description Uplink
interface GigabitEthernet6/0/2
interface GigabitEthernet6/0/3
--More--                           !
interface GigabitEthernet6/0/4
--More--                           interface GigabitEthernet7/0/1
interface GigabitEthernet7/0/2
interface GigabitEthernet7/0/3
interface GigabitEthernet7/0/4
interface FastEthernet8/0/29
description ISP 2 INTERNET LINE
switchport access vlan 253
switchport mode access
interface FastEthernet8/0/30
description  INTERNET LAN
switchport access vlan 254
spanning-tree portfast
interface FastEthernet8/0/31
description WAN 1 ISP 1
switchport access vlan 252
interface FastEthernet8/0/32
description WAN 2 ISP 2
interface GigabitEthernet8/0/1
interface GigabitEthernet8/0/2
interface GigabitEthernet8/0/3
interface GigabitEthernet8/0/4
interface Vlan1
description Legacy Network
no ip address
interface Vlan2
description Switch Management
ip address 10.3.1.31 255.255.255.0
interface Vlan252
no ip address
interface Vlan253
no ip address
interface Vlan254
ip address 10.3.254.20 255.255.255.0
router eigrp 1
eigrp stub connected
network 10.3.1.0 0.0.0.255
network 10.3.254.0 0.0.0.255
ip default-gateway 10.3.1.11
ip classless
ip route 10.1.3.40 255.255.255.255 10.2.0.229
ip route 10.1.5.254 255.255.255.255 10.2.0.229
ip http server
Has this ever worked? If this is new, I wonder if it was an order of events in the way it was created. The 2 switches should see that subnet as connected, so it's not a routing issue. I would remove the l3 svi and vlan and start over. Create the l2 vlan first, then create your l3 svi and see if you get a different result.
HTH,
John
HTH, John *** Please rate all useful posts ***
8 Replies 8
John Blakley
Can you post "show int trunk" from both sides?
6503
Port      Mode         Encapsulation  Status        Native vlan
Gi3/1     on           802.1q         trunking      1
Gi3/2     on           802.1q         trunking      1
Gi3/3     on           802.1q         trunking      1
Gi3/4     on           802.1q         trunking      1
Gi3/24    on           802.1q         trunking      1
Port      Vlans allowed on trunk
Gi3/1     1-2,10-11,20-22,30,110-111,120-122,130,252-254
Gi3/2     1-2,22,122
Gi3/3     1-2,20-22,120-122
Gi3/4     1-2,10-11,30,99,110-111,120,130
Gi3/24    1,70-71,99,252-254
Port      Vlans allowed and active in management domain
Gi3/1     1-2,10-11,20-22,30,110-111,120-122,130,254
Gi3/2     1-2,22,122
Gi3/24    1,70-71,99,254
Port      Vlans in spanning tree forwarding state and not pruned
Gi3/2     1-2,22,122
3750
Gi1/0/1     on               802.1q         trunking      1
Gi2/0/1     on               802.1q         trunking      1
Gi5/0/1     auto             n-802.1q       trunking      1
Gi6/0/1     on               802.1q         trunking      1
Gi1/0/1     1-2,10-11,30,99,110-111,120,130,252-254
Gi2/0/1     1-4094
Gi5/0/1     1-4094
Gi6/0/1     1-2,10-11,30,99,110-111,120,130,252-254
Gi1/0/1     1-2,10-11,30,99,110-111,120,130,254
Gi2/0/1     1-2,10-11,20-22,30,70-71,90,99,110-111,120-122,130,254
Gi5/0/1     1-2,10-11,20-22,30,70-71,90,99,110-111,120-122,130,254
Gi6/0/1     1-2,10-11,30,99,110-111,120,130,254
Gi1/0/1     1-2,11,99,111,254
Gi6/0/1     10,30,99,110,120,130,254
If you specifically source vlan254, does it still not ping?
ping <3750 vlan 254 ip> source vlan254
on each device i can ping their directly connected ip.  but i cant ping each others across the trunk.
Can you post "show int vlan 254" from both sides?
6503
Vlan254 is up, line protocol is up
  Hardware is EtherSVI, address is 001c.b0b7.f0c0 (bia 001c.b0b7.f0c0)
  Internet address is 10.3.254.21/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Last input 01:41:00, output 00:00:03, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
  L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicast)
     2272 packets output, 281287 bytes, 0 underruns
     0 output errors, 0 interface resets
3750
  Hardware is EtherSVI, address is 001f.261e.aec3 (bia 001f.261e.aec3)
  Internet address is 10.3.254.20/24
     reliability 255/255, txload 1/255, rxload 0/255
  Keepalive not supported
  Last input 00:00:07, output 00:00:01, output hang never
     2962 packets input, 177720 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     1628 packets output, 136438 bytes, 0 underruns
HTH,
John
i havent had a chance to add an ip to the svi yet but i am atleast able to ping across the trunk now.  thank you John.
