Dot1q
jeaton
Community Member
I have a 1921 configured to do Dot1Q encapsulaton
I have two network which I control with the Dot1q
I have been using switches ver 12.2 3560 which support the Dot1q encapsulation
I have just purchased a C2950tt-s  ver 12.2 which doesn't have the option for
"switchport trunk encapsulation dot1q"
Is there an option to turn this on, or is ther another way of setting this up?
6 Replies 6
John Blakley
Joe,
The two types of encapsulation were ISL and dot1q. The later model switches don't support ISL because Cisco is moving away from it (it was Cisco proprietary). If you don't have the option, the dot1q is already supported. To see this, you can do a "show int trunk" and you would see "n-802.1q" or just "802.1q" in the column.
HTH,
John
HTH, John *** Please rate all useful posts ***
When I do the show int trunk it return nothing
That just means you don't have a trunk established with another switch yet. Do you have this one connected to another switch?
No its connect to a 1921 router doing the Dot1q
Here's a show int trunk were both the switch and router are config for Dot1q
Port        Mode         Encapsulation  Status        Native vlan
Fa0/46      on           802.1q         trunking      1
Port        Vlans allowed on trunk
Fa0/46      1-4094
Port        Vlans allowed and active in management domain
Fa0/46      1-2
Port        Vlans in spanning tree forwarding state and not pruned
Fa0/46      1-2
Joe,
The router connects to the switch? You'd need to trunk the port on the switch manually because routers don't support DTP. The information that you just posted indicates (Mode on) that it's a static trunk. You can do this with "switchport mode trunk" on the interface that the router connects to and you should be set.
HTH,
John
**** Please rate useful posts ****
If both side of switches configured correctly with trunk we able to see by command
sh int trunk
To see which VLANs are allowed through trunk and native VLAN, and trunk protocol such as dot1q.
Both sides must have same native vlan and trunking protocol.
Hope it will help.
Best regards,
Abzal
